I have a Meridian 9516cw. It was disconnected , then reconnected. It now has a continuous "Please Wait" with no dialtone or keypad function when plugged into AC. It it possible to reset this phone? There is no obvious reset button. What do you suggest to get this phone functional/ Thanks for your help.
Same issue. One day I walk in my den and the phone is at Please wait..., the Handsfree/Mute LED is blinking, and there's a tick TOCK sound (fainter tick when LED is off, louder TOCK when the LED is on). Tried unplugging for hours, 'raking' the buttons, unplugging all cords. It is fairly old and perhaps the logic board has failed.
SOURCE: M7310 Panic Button
Not sure which system you have but it sounds to me like you are looking to make a group that contains all your phone extensions. It's like calling an extension number for a specific phone but in this case it would be a group extension number that contains a list of all your phones. It may be called a "hunt group" and you would want to set it up so all phones ring simultaneously, not in order. Then you program a key on all your phones to call that group extension number.
SOURCE: Every button including feature Meridian 7310 calls to an internal
Sounds like a stuck button.
Do what I call the rake... swipe at the keypad over and over, look to see if there is any button lower or depressed on the keypad or buttons.
Someone may have spilled something on it (cola, coffee), and the set may require to be taken apart if there is a stuck button.
