Washer stops working and a F11 code is displayed. Can jiggle some of the wires around and some times it will restart. The washer will not complete the cycle for washing a load of clothes. Any suggestions?
Well your close f11 is a motor control unit error or a loose connection in the wiring harness from the mcu to the motor or from the mcu up to the control panel the mcu is under the bottom kick panel un plug the washer safety first then start at the motor follow the wires back to the mcu checking wires and connectors then form the mcu up to the control board check your motor for continuity normal should be about 6 ohms between pins 1&2 then same at pins 2&3 same at pins 1&3 your motor maybe overheating and tripping out on overload then restarting when the washer motor cools down if all that checks get back with me and we will run diag on it
I was washing a load of clothes when washer stopped and flashed f 11 on display screen
