Jenn-Air JED8430 Electric Cooktop Logo
Posted on Dec 28, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
JED8430 Fan Burning
Just purchased and installed a new JED8430 down draft in my kitchen island. Installation was fairly straight forward, as I was replacing an older Jenn Air downdraft.
Three wires to connect, black, white and ground and things seemed to be good. All burners work and light correctly.
When I turn the fan on, it will run for 30-60 seconds and then shut down and there is a terrible burned smell.
Any way to trouble shoot this?
Thanks in advance.
  • 2 more comments
  • crs34 Dec 30, 2007
    Figured it out. I'm not all that mechanicaly inclined. When read the wiring diagram, I saw three wires and assumed they were the black, white and ground. I missed the red wire which was still tucked in the stove. So, the problem was incorrect wiring, and my fan was overheating and the burners were only getting 110. Rewired this afternoon and all is well.
  • crs34 Dec 31, 2007
    True. If I hadn't found a sentient life form where I bought the top (Lowes) I was ready to put the old one back in and take the new one back. This guy actually pulled one of the display models out and showed me what to do and wrote some directions. He knew what he was talking about, which means he will probabaly get fired soon and that store will be back to the status quo answer of "I don't know". I have GOT to take a basic electrician and small engine repair class before I die.
  • comerfom Jan 05, 2008
    I have the same cooktop and the same problem. What did you connect the red wire to? Black? Thanks, Matt
  • Anonymous Mar 22, 2014
    down draft fan does not work
Anonymous
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Dec 30, 2007
Anonymous
Master
Level 3:
President:
Answers
1314
Questions
6
Helped
897821
Points
3823
Great love it when people do this just commom sense most of the time
How do I replace the switch for a jennair electric cooktop? model jed8430adb. Thanks!
You first need to remove the unit from its installation. Start by disconnecting the exhaust fan from the ductwork. Then push the cooktop up.
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also at the top of the down draft cavity (the down draft cavity is where the grease guard mesh is)
Cold air from outside enters the kitchen through the down draft vent.
its would be best to install a damper
whether auto matic
or manuely operated
this is a common problem for the down draft
ive seen some people install things similar
to dryer vent louvers,
but check you exhaust area and still if you can block direct draft
but dont block it so that it cannot exhaust properly
3helpful
The jenair made a popping sound, wasn't even turned on. Then found it didn't work at all. Flipped the breaker, and it would immediately flip back, the Jenair would also make the same popping sound.... Do...
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at Searspartsdirect.com - search using the cooktop model number).
To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity (the down draft cavity is where the grease guard mesh is)
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
1helpful
How do you get the black top off. I have to put in a new front burner. Thanks.
Turn off the circuit breaker to the cooktop. Verify by making sure the burners/fan do not come on. Disconnect the exhaust fan (underneath the cooktop) from the ductwork by removing the tape that joins it. While you are underneath the cooktop, open the junction box. Label the four wires that are joined so that you will be able to connect them later. Then disconnect the four wires. Remove the metal sheating that connects to the junction box (there is a nut on the inside of the junction box that you loosen. Pull out all the supply wires (from the mains) from the junction box. Then push the cooktop up and out and lay it flat on a table with the flat side down.
Take off only the top row of screws all around the unit. Rotate the unit so that you can get to the down draft cavity (the down draft cavity is where the grease guard mesh is). Remove the two center screws. Then pull the black top off.
For an exploded view of the unit check out
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47639&diagram_id=681565#d681565
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
2answers
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
3answers
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Top Jenn-Air Cooktops Experts
Paul Carew
Paul Bade
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
