Question about HP Photosmart C7250 All-In-One Thermal Printer
I have an HP Photosmart C7250. A few days ago,
I have an HP Photosmart C7250. A few days ago, the printer took a few sheets of paper at once and jammed. I removed the jam. Since then, the printer jams everytime I use it. What can I do?
I have the same problem
Posted on Dec 20, 2009
SOURCE:
My hp c7250 printer will not recognize paper in main tray and gives me an out of paper error message. How do I get the printer to recognize paper?
My C7250 just did the same thing a couple of minutes ago. It works now but I'm not sure what did the trick. I put in a single sheet and pushed it with my finger. After a couple of tries doing this, it grabbed the paper and printed.
So far it has printed 5 sheets without a problem.
Nov 27, 2010 | HP Office Equipment & Supplies
HP C7250 scanning problem
Scan a BLANK sheet of paper.
if you have that black strip it means there sre two possibilities:
>> the scanner glass is not screen
OR
>> the scanner is faulty.
Clean the glass properly using a moist lint free cloth.(do not use alcohol)
if the issue still persists
The only option that you have is to get the printer replaced.
If your printer is still under warranty(i.e if its still not an year old) you can get a free replacement from HP.
wherein they will send you a new printer absolutely FREE OF COST
if its not in warranty then you can opt for the UPGRADE option that HP has.
You can send them this faulty printer and get a LATEST PRINTER at a huge discount..
here's the number to call
1800-474-6836
Sep 25, 2009 | HP Photosmart C7250 All-In-One Thermal...
My HP C7250 inserts a blank page between every printed page. Windows Vista PC.
Perhaps this is a characteristic of the document being printed: Manual paper feeds in addition to the automatic paper feed characters? Use the word processing program matching the document to remove the unwanted paper feeds.
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 AIO won't print wirelessly from my laptop
Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
Hope this helps!
-michan-
Jul 20, 2009 | HP Photosmart C7250 All-In-One Thermal...
My HP printer spits out a blank page before printing document
I had same problem with hp psc 2410 all-in-one. Finally ran "HP all-in-one Series Web Release Uninstaller version: 4.1.1.00.1332 (3/20/2007) that I had downloaded several years ago. Then plug and play took over and installed the correct driver that Vista kept insisting I already had.
May 09, 2009 | HP - HP Photosmart 8250 printer
HP paper feeding issues
you can put only a few sheets in at once, and then push the sheet a little bit until the printer takes it, once it does that, try a few sheets at once and you should still have to make the printer take the first but after that they should all take normally.
Dec 02, 2008 | HP PhotoSmart C4280 Laser Printer
Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Aug 02, 2008 | HP Photosmart C7280 Laser Printer
HP Photosmart C7250 All-In-One Thermal Printer Logo
522 people viewed this question
Clive
Clive
Thomas F. Schneider
