Panasonic KX-TG5673 Trio Cordless Phone Logo
Posted on Oct 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic phone system, won't release the phone line
We had a power outage. when the power came back, my panasonic corless phone system kx-tg5673 went to dialtone automatically even tho it was off. It then then hung up the line and wouldn't release it even when i pushed off both on the handset and on the base. It will only release the line if I unplug the phone line.
Anonymous
Level 3:
  • Master 396 Answers
  • Posted on Oct 16, 2009
Anonymous
Master
Level 3:
Answers
396
Questions
0
Helped
168200
Points
1304
You might try removing the battery pack and see if that resets the phone. If not, you probably have a component inside the phone that has failed.
On most cordless phones, it is not cost effective to have them repaired.
Would like to know if I can get a replacement phone model kxtg5632anasonic
You should be able to find it on ebay
http://www.ebay.com/itm/Panasonic-KX-TGA560-kx-tg5632-Accessory-handset-kx-tga560b-KX-TG5673-KX-TG5672-/390677723382
Panasonic CORDLESS
1st check that the charger is plugged and energized. It should light up when dropping a hanset into the craddle.
2nd Check that the batteries are connected properly inside the handset and that they have the full voltage. Try 1st step again
1helpful
Can't use phone, says ''no link to base, move closer to base, try
disconnected all phones from the wall, left unplugged for 15 minutes, when plugged back in, they worked
We have a panasonic cordless telephone # KX-TG5632. Yesterday, we were having some electrical work done and now that the power is back on, our corless phone does not work. There is power to the phone but...
Does the phone base receiver also have power? If so, then it sounds like a phone wire may have been cut. How extensive was this electrical work? If an electrician cut your phone wire by mistake they should take care of the problem at no charge.
To eliminate any problems with your cordless phone, try plugging in a standard phone where your cordless unit is to see if the line works.
HELP! power outage problem
Your burglar alarm panel, shorts the phone line when it sounds off, while it is auto dialing out. So that is why no phone.
My strong recommendations is to use a UPS on all of the items that are on the phone line. Problem should be solved.
You don need big ones either. Small ones will do just fine. I have them too.
www.storminproteciton.com
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
