? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
We have several parts here for the Proheat 2X, Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
If you haven't been cleaning the filters after each use now is the time to get that done. Turn the Flow Indicator Cap counter-clockwise and remove it. Lift the rotor out and under it is the filter. Clean and reinstall in the reverse order. Now under the Water Tank Cap is another filter that looks like a screen. Remove it and clean and replace. Now try your machine. If that didn't do it call Bissell Consumer Care at 1-800-237-7691
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Did this start happening after you removed the clear side pieces, to clean around the brushes? You may have loosened or removed the black plastic arms that hold the brushes in place off the floor. One goes on each side, and is mounted to the Bissell with a silver screw with a built in washer. The brushes fit inside these two arms, and they are also held in position by the black belts. The big one goes around both brushes on the left side as I face the machine. The small one goes around the back brush and a small cog on the right side, as I face the Bissell.
