Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
Posted on Nov 19, 2017
Samsung HLR5064W - Replaced the color wheel and now there is a Green/Blue cast over the screen. Called Samsung to troubleshoot and they want to send a service person! If I could figure out that the problem was the color wheel in the first place and figured out how to istall it, theres got to be a way I can fix this too! HELP!!!
5 Related Answers
Anonymous
  • Posted on Oct 17, 2008
SOURCE: CCA Values For Samsung TV
With the TV off, you need to push
Mute-1-8-2-Power very fast. just wait and it will show up.
If the tv is on press Power-mute-1-8-2-Power and it will show up as well. Good luck, I am still trying to fix the CCA values myself. When you get in the Service Menu, just use the arrows to get around and to get back use the menu key.....
Anonymous
  • 5138 Answers
  • Posted on Dec 25, 2008
SOURCE: Samsung DLP HLN617 61" start
Light Engine call UED ask if they have rebulit one 1-800-648-6657.
Anonymous
  • 184 Answers
  • Posted on Feb 19, 2009
SOURCE: Samsung HLP4663W Black Solarization
The speed of the color wheel needs to adjusted or the CCA values. Both are found in the service menu . If you paid a company to fix the TV, call them and tell them that they forgot to perform these alignments. If you did the repair yourself, you'll have to call around for a price to have a Samsung service center perform these adjustments. I don't recommend consumers access the service menus of modern TVs because one wrong button push and you may cause irrepairable changes to the TV's proper operation.
michtech
Anonymous
  • Posted on Mar 10, 2009
SOURCE: samsung HLP4663W color wheel replacement
When I removed the jumper wire the screen color problems I experienced after changing the color wheel were fixed completely. I did not need to reset the CCA values (which came with my color wheel, on a separate sticker). If you have a black bracket blocking access to the jumper wire, as I did, you can access the jumper wire by removing the fan shown just to the left of the yellow and white sticker; there are two screws attaching the fan to the chassis below it. Next, remove the two screws that hold the silver clamshell (the housing for the circuit board) halves together. These screws are right behind where the fan just was, on either side of the protruding fins. They each have a spring under the screw head. You can then pull the visible half of the silver housing forward (with the bracket attached). You will then have access to the entire circuit board. Look for CN810 - it is located right behind where that bracket just was when it was all put together. Pull the tiny black plastic part (that has the jumper wire) off of the pins. Then reassemble the housing and put the fan back on.
Anonymous
  • Posted on May 24, 2009
SOURCE: adjusting color after color wheel replacement samsung dlp tv
There should be a jumper somewhere around the color wheel. I am having a problem with my color wheel, and after doing a lot of research I found that people that have the same problem as you changed the jumper setting. Try looking it up here on the net. Should solve your problem.
Samsung HLR5064W DLP TV load vibrating noise like a fan blade hitting something, lamp light is one, Tv will light up but discolored
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_3_58_01_pm.jpg
The TV is making a grinding sound. Picture is still fine. What could be the problem?
You have Color Wheel Failure. Light engine must be removed to access and replace the color wheel.
This page shows Samsung Color Wheel part number for different TV Models. This page shows Color Wheel Replacement service cost in Canada.
[email protected]
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
Blurry after Installing Colro Wheel?
Hi,since you are getting the new silver air pressure version you will need to put an jumper to the dmd board,why because gold version spins different than sliver and that will produce the tv to have color discoloration or bluryness.Good luck and God bless you!
My Samsung HLR5064W just started to make a grinding/rubbing sound. The colour/picture immediately became distorted. Colour is now incorrect with green and red the dominent hue.
Bad Color Wheel call Encompass for part 1-800-638-3328 Heres another Tip these TVs have high failure rate on Light Engine, DMD Board. For Light Engine Call UED 1-800-648-6657
1helpful
2answers
My set is the SAMSUNG LHP5063W. I replaced the color wheel Sunday and got horrible colors. The Part number ordered was BP96-00674A The number on top of the color wheel top is L3 BP61-01687A but I do n
The new color wheel is different from the original. The original used an Air Bearing type motor. But the replacement type is a standard bushing type motor. There is a jumper on the rear of the DMD board that may or may not be covered with a paper sticker. Reposition the jumper to accommodate the new color wheel.
3helpful
4answers
Color is bad after installing color wheel in samsung dlp tv
Most times color does not to be reset. If you have a very ugly green or blue picture, then you did not pull the jumper on the dm board. This jumper must be removed when a bering type color wheel has be replaced with a new airless bering color wheel.
2answers
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
