Hi
Thanks for using FixYa. You’ll
need to clean the filter which is located on the front bottom of the washing
machine right below the washer window. It is held up by three screws. Take out
the screws and clean the lint. You’ll find in the lint some small clothing,
coins and other small things.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
RYLEE YOU ARE AWESOME! THANK YOU SO MUCH. I HAVE THE CRAPPY GE FRONT LOAD WASHER TOO. BEING A SINGLE MOM ON A NURSE SALARY, I COULDN'T AFFORD TO HIRE A REPAIRMAN. MY WASHER KEPT PAUSING MID CYCLE. I RESEARCHED IT, AND CAME ACROSS YOUR INPUT. I UNSCREWED THE FILTER PANAL, CLEANED THE FILTER, DID THE UNPLUGAND REST. IT WORKS LIKE NEW, AND YOU MADE ME FEEL TEN TIMES SMARTER!! LOL. PLEASE EMAIL ME AT [email protected] IF YOU EVER GET SICK AND NEED ANTIBIOTICS! MUCH LOVE TO YOU!!!
Well Thank You!!! took me around 3 minutes to fix and I feel like I have a new washer!! and on top of this I got paid for it, I found just over a buck in small change! thanks again
After I cleaning the filter i still have the same problem my washer still stopping in the middle of the cycle it will wash just for a little bit and it will stop again
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Hi Lance - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
