Televison & Video Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My magnavox tv is making a buzzing sound, no picture, and wont change channels (just a dark screen)
Anonymous
Level 3:
  • Master 541 Answers
  • Posted on Oct 15, 2009
Anonymous
Master
Level 3:
Answers
541
Questions
Helped
126486
Points
1217
Something has shorted in the set causing the power supply to make that buzzing sound. Most likely the short is in the horizontal circuit. The horizontal makes the high voltage work which in turn lights the picture tube.
Dark picture on screen
change your settings from natural to brillent on your tv , note the bulb wont last as long on brillent because of the extra power it takes to run it , try that and see if its what your looking for
Screen comes on ... no sound or picture only header info, at top with channel info.... then the screen goes dark not any thing .
The power supply startup resistors on the inverter board may have changed values. Youwill have to replace the inverter board. Thanks for asking !
1helpful
TV goes black, no sound or picture. Changing channels twice brings it back. Happening for a while now. Recently screen is dark, can see but not well.
There are several possibilite here, including the power supply, video amplifer circuit, and high voltage.
However, there is a componet on the main board that is the most likley fault. R3455 should be inspected and repaired or replaced as necessary.
Thank you
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Philips Magnavox 36" @10yr old has perfect sound and black screen
checked the vedeo section of the main PCB of the unit, maybe some defective parts, try to look the back of the picture tube if theres a light, if none, cheke also the horizontal section, especially the flyback transformer
Dark colors Picture going out
It is hooked up to Direct TV. When I change the channel on the TV to another input it looks fine but without a picture. as you do not see tint in another channel means your color section is ok it is due to video or luminance section.
2answers
Philips Magnavox 27" TV - no picture and buzzing sound
Are you using the video input? Do you get on screen display? If so you probably have the video (yellow) wire connected to one of the audio inputs.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
