help my tv is black and won't go on. RED LIGHT is FLASHING HELP, HELP, HELP Nowwwww PLEASEhelp my tv is black and won't go on. RED LIGHT is FLASHING HELP, HELP, HELP Nowwwww PLEASE
AnonymousMay 21, 2008
already paid to have tv fixed when it would not turn on and was blinking seven times...now it blinks four times and the picture either does not come on for several minutes or it does not come on at all. they are supposed to try again but am not sure it is worth it when I have already paid almost 400 dollars in repairs.already paid to have tv fixed when it would not turn on and was blinking seven times...now it blinks four times and the picture either does not come on for several minutes or it does not come on at all. they are supposed to try again but am not sure it is worth it when I have already paid almost 400 dollars in repairs.
AnonymousAug 16, 2008
Stand By light blinks and then goes off. TV will not turn on, please advise solution.Stand By light blinks and then goes off. TV will not turn on, please advise solution.
You can't post conmments that contain an email address.
the light indicates an internal electronic fault with your set projection TV`s have integrated protection circuits built into the circuit design, these circuits turn the power off automatically when a fault has bin detected this is in order to prevent a more costly repair, these circuits monitor power supply , vertical and horizontal deflection over voltage, or x ray, and also faults with convergence circuits. Diagnosing these faults require test equipment and a good knowledge of electronic repair techniques, and also a repair manual.
The standby light should be blinking in a repeated pattern. Count the blinks and report that number here. This will indicate the circuit that is defective and will allow us to provide a repair suggestion.
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Replace the horizontal output transistor (Q502) and check the electrolytic caps in the vicinty, unsing an ESR meter. PLEASE NOTE THAT THE TV TUBE MIGHT BE CHARGE WITH ABOUT 27,000 VOLTS.
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
the red light blinks 4 times tv does not come on
I have the same problem = red light blinks when TV is off - then when turned on it blinks four times and TV shuts off .
Is there an easy fix?
