Dell Inspiron 6000 Notebook Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Laptop doesnt start at all . I dont know what
My Laptop doesnt start at all . I dont know what happened but no LED lights light up
Anonymous
Level 2:
Novelist:
  • Expert 225 Answers
  • Posted on Oct 15, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
225
Questions
0
Helped
97270
Points
402
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
newman
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 09, 2013
newman
Contributor
Level 1:
New Friend:
Answers
Questions
7
Helped
523
Points
Thank you very much .When i remove the battery of my Asus laptop as you instructed the laptop light beep and stay on,and start working but only with the AC Adaptor,with the battery again it didnt funtion.It function only when it is without the battery.
What could be the problem in such case?
Thanks once again
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
My Fathers toshiba turns on for a few seconds (with lights, fan, and a all black screen) then suddenly just turns of!!! What do i do??? HELP
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
My fujitsu laptop doesnt start
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
My hp dv2988se not powering on just displays all the led light then the
search the reset button below your lappy use a saftey pin to press it.
your lappy will restart .
6helpful
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
1helpful
When connected to mains adapter the 2 left side LEDs on the front of the computer {standby+mains connected]start to flash and doesnt charg
This happens when the battery will not hold a charge. You will need a replacement battery if you want that light to go away.
If the battery has not been like that too long
put in a plastic bag and freeze overnight
let thaw until room temp
insert battery
plug in jack
do not power on laptop
let charge for1 hour
then try
Need a manual . the led doesnt light up so i dont know what is happening to the unit when i push the various buttons
check out
www.mobileinformationlab.com
that should be able to help.
first can you clarify what led you would be speaking of? is it the main display of the unit or the buttons are not illuminating? let me know and ill try to help you.
Start up
yr problem should be from the screen to really confirm if yr laptop is truly on cos u dont just gudge by seing the power led on. to check if yr system is on press the caps lock key or press the fn+num lock key if the indicator led comes on then yr system os on now troubleshoot yr screen by checking the module,connector n fuses. if the caps lock led doesnt come on then yr system just powered on because it saw a power source in that case try to replace the memory(ram) next the processor.
guess this helps
thanks for using fixya
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
