Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
Posted on Oct 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My ceiling fans original remote is broken adn I need to get a code to set the universal remote to turn on/off my fan
Jack Jr
Level 2:
New Friend:
  • Expert 46 Answers
  • Posted on Oct 17, 2009
 Jack Jr
Expert
Level 2:
New Friend:
Answers
46
Questions
0
Helped
63937
Points
108
While it's true a lot of ceiling fan remotes and receivers are universal, there are exceptions. Obviously you need a dedicated ceiling fan remote, not something picked up at a local wal-mart that controls t.v.'s and dvr's. I would need to know what kind of system you have. One of the most common types is a UC7067 4 dipswitch (64 -bit) sytem. Look in the battery compartment of your remote for 4 tiny micro switches this will let you know. If you have this system, you can get replacement parts from www.fanmanlighting.com or call them at 1-866-600-3267
Lost remote
Well you can purchase a universal remote in place of your lost remote. You need to connect the universal remote to your fan, universal remotes have a code search button or sequence. Turn on your fan, activate code search, & press the power button until the appliance turns off, then press the set button. or use the manual book provided by the universal remote manufacturer.
Good Luck!!
Thanks for using FixYa!!
1helpful
Remote control not working
Dear Sir/madam,
Check these steps........
1. Adjusting the dip switches:
Each fan/remote combination is set to work on a specific frequency, much like tuning in a specifc radio station. Some fans allow you to set this frequency by means of a set of small switches called "dip switches". There is one set located inside the remote, and the other set would be position on the fan, with the remote receiver electronics. This would be either on top of the motor, or inside the switch housing or ceiling canopy. These switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and/or try a different setting. They are also useful if you have two remote fans, you will want to be sure each fan is set different so the remotes do not interfere. Lastly, if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
2. Universal remotes:
If your fan remote is lost or broken, many suppliers, including this web site, offer a universal remote designed to work with the majority of different remote operated ceiling fans. Many are also universal for operating televions etc so you can control all your leisure and comfort devices from one unit.
3. Replacement parts:
Unfortunately, outside of Universal remotes, general replacement parts are not available for remote control systems. Your best bet is to contact the manufacturer.
3a. Repair:
Also unforunately, most problems with remote controls cannot be repaired outside of what is suggested above. If you have problems, contact the manufacturer, perhaps the fan is under warranty, or parts are available. Otherwise chances are the fan will stay broken.
4. Converting to 3 speed:
One common question: My fan's remote is broken, can I just convert it to a 3 speed pullchain like other fans? Again unfortunately, if you have to ask the question, then chances are the answer is no. It can be done but there are no universal directions, it varies drastically from fan motor to fan motor, and requires a fair amount of technical and electronic skill. A few exceptions: If the fan has a "remote bypass" switch you can select it and then use a wall control (or pullchain if there is one attached to the fan). Or . . .
5. Add-on remote kits
Some fan remote systems are not built into the fan, they were an option added by the installer at an additional cost. Usually they consist of a remote receiver wired to the fan inside the ceiling canopy, and the fan will still have a pullchain that is not used. If this is the case then the receiver can be removed and replaced with another remote/receiver kit, or the fan can be operated as standard with the 3 speed pullchain.
thanks
good luck
How to install universal remote in a 52 " hampton bay ceiling fan ,model # 24754
Universal remotes have a code search button or sequence. Turn on your appliance, activate code search, & press the power button until the appliance turns off, then press the set button.
3helpful
Two fans with the same remote code.
There are dip-switches in both the remote and the fan. You need to change the switches on one of your fans.
1helpful
I have 2 fans 1 stopped working 1 remote
Look at the remote code on the remote which is broken, then copy the code on the fixed remote, then you can control anoher fan.
Remote will turn on the light, but not the fan.
I have a white Westinghouse tv and can not programs the code in a Rca universal remote control
could you give me the code for the tv. Thank you
Nardin
4helpful
2answers
Ceiling fans on same frequency
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Originally answered by d0n0r in this question
2helpful
2answers
Need manual to program remote to a different frequency
Each fan with have a receiver unit mounted in the housing, usually above the fan up against the ceiling. Each receiver unit will have 4 "dip pins" which allow the code to the remote to be set. In order for two fans originally installed with the same code to be run separately, one fan will have to be taken down, and the code changed on the receiver unit. Then you will have to purchase a new remote and set the same code on its dip pins (usually under the battery.) It's easiest to buy a replacement remote WITH a receiver AND a transmitter in it. You can either wire in the new receiver (setting the code differently than the existing one on BOTH the receiver AND the transmitter) OR just put the receiver aside and program the new code that you've set in the old one into the transmitter.
No connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Top Universal Remote Control Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
