I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
My new blackberry bold 9000 do not want to switch on. I have charged the battery and still nothing. When I plug it in to charge the red light comes on and then it switches to a white screen with a battery and a red line thru it. it worked awesome for one day...I haven't even plug it into my mac yet...what should I do
This may happen because Application Loader tool in BlackBerry Desktop Manager removed existing applications from the BlackBerry smartphone, but failed to install new applications.
Complete the following steps:
1) Verify that BlackBerry Device Software is installed on the computer.
2) If the BlackBerry smartphone is connected to a laptop computer using a docking station, disconnect the docking station from the laptop computer and connect the BlackBerry smartphone directly to the laptop computer.
3) If a third-party application uses the same communications port as the BlackBerry Desktop Software, close the third-party application.
4) If you use a USB adapter to connect the BlackBerry smartphone to a serial port, temporarily connect the BlackBerry smartphone to a USB port.
5) In the BlackBerry Desktop Manager, double-click Application Loader.
6) Follow the Application Loader tool prompts to install the BlackBerry Device Software.
I am having the same problem.My bold was working great last night and i went to bed and it had almost a full charge and when i woke up this morning it was dead.When i plug it in to the wall charger the red led comes on for about 30 seconds tehn it turns off and teh screen turns white with a battery on it with a lightning bolt throught it for about 5 seconds then it turns off and nothing it just wont turn on.I tried 3 different batterys(fully charged) and still nothing.i can be reached at valasara(AT)hotmail.com
