Question about Mercedes-Benz Vehicle Parts & Accessories
Mercedes Benz Sl 500 ( 1991) Model Aust/Delivered. Soft Top Works Manually, & Does not operate Electrically, what could be The Common Problem . Kind Rgds Frank Jansz
SOURCE:
3mac
  • 61 Answers
SOURCE: Transmission Fluid - 1987 Mercedes-Benz Diesel Turbo
It took Mercon Dextron III.
Of course, MD IV, V or Mutli-Vehicle would be better (the new multi-vehicle formula is what is being widely recommended by all nowadays).
Posted on Jan 19, 2009
lastech
  • 408 Answers
SOURCE: how do you remove the center console in a 1982 Mercedes benz 380S
hi,center console or center gear lever cover(wooden console)
  • remove radio,then remove control unit of aircon by pressing down the 2 latch,located in upper edge in radio hole.remove screw in upper part of console
  • remove black cover (look like astray)fold both side,remove screw
  • remove shifting lever
  • try to lift in the console,be careful,sometimes sticky
Posted on Mar 22, 2009
  • 62 Answers
SOURCE: I can't open the trunk of my 1985 Mercedes Benz
Check your trunk release fuse in fusebox. I used a locksmith for mine when all thaT FAILED.:)
Posted on Sep 08, 2009
  • 59 Answers
SOURCE: Recently started having problems with convertible
hopefully will be a easy fix this one, first check the micro-switches for the roof assembly (in the boot) and check any ground wire connections
you could try resetting the system also as this may help
if its still the same after this post back and ill try and help again.
tneubauer
  • 437 Answers
SOURCE: how to reset airbag for mercedes benz c220 1994
This can not be reset by conventional methods. This must be done through a scan tool. Usually only the dealer scan tool will communicate with the SRS module. If the SRS light is on you have other issues and they must be remedied before the light will go out. There is no way of knowing what the issue is without running codes with the scan tool.
Posted on Feb 10, 2010
Replacing the hard top on a Mercedes SL 320. The roof has docked at the offside front but none of the other points are in. However, now I cannot release the one point that has gone in... Is there an...
yes there is a manual release for the locks. Hopefully you still have the tool kit with the soft top tool in it. It will have a open wrench on one side and a allen on the other. For the rear locks use the open end wrench side and behind the side trunk panels you can see the mechanism for the rear latches. Slide the tool over the release mechanism and move upwards while lifting up on the top. For the front latches swing the visors to the side and remove little round cover. Insert allen side of tool and rotate until latch unlocks. Make sure vehicle is running when ever you operate the top or hard top as voltage can affect the operation of the latches.
Oct 08, 2010 | 1997 Mercedes-Benz Mercedes Benz Sl Class
I have a mercedes sl320 1997, need to know how can i release the hart top manually?
Jul 19, 2010 | 1997 Mercedes-Benz Mercedes Benz Sl Class
I need to raise the soft top on my mercedes 500 sl but when i try with the switch it makes a noise but nothing happens is there a way to raise it manualy
There is no way to raise it manually. You most likely have bad seals/pistons that have leaked out the fluid. Check your manual for where you can put fluid into it, and pop over to benzworld.org for group help on mercedes issues.
Jun 11, 2010 | 1995 Mercedes-Benz SL-Class
How do you manually remove the hard top off a mercedes sl 700
Suggest reading how to in owners manual. If you dont have it go to dealership and get a new one. Lots of how to and service for the top.
Apr 14, 2010 | 2007 Mercedes-Benz SL-Class
1995 SL500 soft top will not go donw
Car must be on a level surface. Make sure hydraulic system is full and pistons dont leak and go from there.
Oct 25, 2009 | 1997 Mercedes-Benz Mercedes Benz Sl Class
I HAVE A 99 500SL. I REMOVED THE HARD TOP NO PROBLEM. THE SOFT TOP WILL NOT GO UP. THE SWITCH FLASHES IN THE UP POSITION AND THE PUMP RUNS IN THE DOWN POSITION. THE RIGHT REAR TOP LOCK IS IN THE LATCHED...
the soft top module is receiving an illogical switch input. try retracting the top untill all the locks are secure. Make sure your roll bar operates o.k.. also only operate this top with the car running and the windows up. If it still won't work I would suggest having the car scanned for codes. You can try disconnecting the negative cable on the battery and secring the top manually and see if reconnecting neg. will clear the memmory.
Aug 02, 2009 | 1995 Mercedes-Benz SL-Class
How do i remove hardtop on a 1990 mercedes sl 500
Assuming the hardtop/soft top system is operating properly-push the red switch in the console towards back of car until the top pops up. Make sure you unplug the defroster harness at the r rear of top (behind passenger seat. It will take 2 people to grab the top and pull it up and off. If this system is inoperable- there is a tool in the tool kit(if not you can buy one at the dealer-called a hard top removal tool) and unlock the 2 locks in the front of the top by the sun visors, and 2 locks located behind the seats by the quarter glass panels and the 2 locks in the rear accessible through the trunk. Your owners manual will describe how to do this procedure. I hope i have been helpful
Jul 24, 2009 | 1990 Mercedes-Benz Mercedes Benz Sl Class
How to lower soft top manually on 1995 SL500?
It depends how much hydraulic pressure you have in the system. Take your softop tool and unlock the rear locks via trunk. see if you can raise the rear of the top (do not force because you will damage a ram). Next unlock your compartment lid and then the front of the top. You may be able to then retract it into it's storage compartment. The manual should also tell you how to release the hydraulic pressure via your pump in the trunk by your spare. hopefully I have been helpful
Jul 15, 2009 | 1995 Mercedes-Benz SL-Class
On my 1991 SL there is a secondary hydraulic ram which is leaking badly. It is located in the roof linkage on the near side. Is it feasible to change this unit without major surgery? Where can I find...
Your softop is actuated via hydraulic rams that close latches and pull cables too move the soft top. It is a common failure. I'am assuming that it is the front latch ram's located above the windsheild.If not they are all very similar. If it is an easy one to remove or if you can see it closely-there will be a mercedes part number on the ram. it will start with a 129 prefix because your model is a 129. it will be followed by a 3 digit number and then a 4 digit. If you can read the nunber call a dealership or independent german garage and give them the number and they can order it for you. Your owner's manual should explain how operate your top manually and how to bleed your hydraulic system. I know from experience with these tops tha if you leave your key on and partially operate your roof to expose these rams it will self retract every 15 minutes so do not have your hands in the way and take your key out of the ignition because once you loose complete hydraullic pressure the roof will move. Good luck
Jun 27, 2009 | 1995 Mercedes-Benz SL-Class
My hard top won't come off when I push the release button is there a manual way to unlatch it
hello,good day,yes it has a manual opening and closing of your hard top,in your tool kit,one spanner is for your hard top,then read your owner manual how to operate manually,ty
May 19, 2009 | 1991 Mercedes-Benz Mercedes Benz Sl Class
Vehicle Parts & Accessories Logo
108 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
