Go to: www.usasupport.philips.com Enter your model number On the next page, click on your exact model number without the "B" on the end On the next page, click on "software and drivers"
If the software and drivers section doesn't help, then go to the FAQ for model SA6087 - there is a patch you can download under the section My GoGear is not recognized by PC - it works for most models of GoGear.
Make sure that your computer is online and connecting to the Internet. Launch the Firmware Manager at Start->Programs->Philips Firmware Manager on your PC
Connect your GoGear to the computer while pressing & holding the key until the Firmware Manager recognize the GoGear and a dialogue box pop up in recover mode.
Click Start to confirm and start recovering the unit to its factory setting IMPORTANT: All music & content of your GoGear Player will be erased once the factory setting is restored.
Follow all screen instructions and click Finish at the end to complete the recovery.
The Firmware manager will close automatically once the success message is displayed. Close all opened application and then safely remove your GoGear by clicking on the EJECT HARDWARE icon in your task tray bar. When prompted, "The USB Mass Storage Device can now be safely removed from the system", click OK and unplug your micro jukebox.
If you have any additional questions or issues, Consumer Care can be reached at 1-888-744-5477. You can also find more information and resources on this product @ http://ow.ly/5R4ZK.
You can download content to a Philips GoGear multimedia player using Windows Media Player or MusicMatch Jukebox in Windows. Earlier versions of Windows starting with 2000/ME and XP are compatible with GoGear. If the device is not recognized by the Windows XP operating system or is receiving error messages, you may have older versions of the necessary software installed. There also may be firmware issues with the GoGear device.
Instructions
Connect the Philips GoGear to another USB port on the computer. Sometimes USB ports go out, especially those in the front of the computer case. Try inserting the GoGear into another port and see if XP can now recognize the device.
Download Service Pack 1 or later for the XP operating system (see Resources). Philips GoGear can only operate on XP systems with at least Service Pack 1 installed. You may also receive an error message pertaining to the service pack when trying to insert the installation disc for the GoGear support software.
Install the latest version of Windows Media Player. Philips GoGear requires at least Windows Media Player 11. Windows Media Player 11 is available for XP .
Install the latest version of MusicMatch Jukebox (see Resources). Earlier version of this software may be causing error messages regarding missing MP3 tag information and missing tracks. Follow the download prompts, then unzip the folder and click on the "HDD_xxx.exe" installation file. The latest version of the software will be installed.
Install the latest firmware on the Philips GoGear. The actual firmware required depends on your GoGear model. Open either Philips Device Manager or Songbird, depending upon which management software you are currently using. Close all programs on the computer except for the Device Manager/Songbird. Connect the GoGear to the power supply and the computer. Click the "Repair" tab in the Device Manager and click "Repair," or click "Tools" in Songbird and select "Check for updated firmware," and the firmware will be updated on the GoGear.
Triple Reset for Philips’ GoGear: Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off.Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab.Reset the player one more time while connected to computer. Follow the repair instructions. After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again. -Tha Mp3 Doctor
This is a way to force the PC to recognize the GoGear and solve your problem. Make sure the hold/lock switch is not engaged first. Note: These instructions only work for the SA6045 - if your Philips is a different model #, these instructions may or may not work:
You do this via your computer. Plug the USB connector into GoGear, and into your USB port on your computer. You open the "Virtual Disc" that has been creaated when you installed the CD, (See disc drives in 'My computer')
Hope this helps
Bryan
Before trying to delete the duplicate songs, first try re-synching your GoGear with Windows Media Player by connecting the GoGear to the computer and clicking on the Sync tab (if you haven't set up the GoGear for automatic sync).
You must use Windows Media Player to delete songs from the GoGear. With your GoGear connected to the PC, you want to highlight (single left click) the icon of the GoGear (or line that says Philips GoGear blah blah blah) on the left hand side of Windows Media Player 11 - this will ensure that you are deleting files from the GoGear itself, and not the computer. Once the GoGear line is highlighted, click on the "Songs" or "Album" folder underneath the GoGear line (NOT the "Songs" or "Album" folder underneath the "Library"). This will bring up a list of songs stored on the GoGear into the middle pane of Windows Media Player 11. Highlight (single left click) a song you want to delete and press the delete button on your computer's keyboard. windows USUALLY gives you a prompt asking if you really want to delete the files/they will be permanently removed from your (GoGear) device. Congratulations, you have just deleted songs from your GoGear! :-)
The HDD 1630 doesn't work particularly well with Windows Media Player 11, so you may have to follow Microsoft's instructions for rolling back to Windows Media Player 10.
