Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Posted on Dec 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mits 62525
OUR LAMP LIGHT WAS RED.REPLACED LAMP(NOT CARTRIDGE)WHEN YOU TURN TV ON SOUND BUT NO PICTURE.IF WE MESS WITH THE LAMP DOOR SOMETIMES WE GET A PICTURE BUT AS SOON AS YOU TURN TV OFF AND BACK ON SOUND BUT NO PICTURE AGAIN.NOW WE CANT GET A PICTURE AT ALL,THE SOUND STAYS ON FOR A FEW MIN. THEN THE LAMP LIGHT TURNS RED AND THE TV SHUTS ITS SELF OFF.WE HAVE RESET TV,AND UNPLUGED IT.DO NOT HAVE AN INPUT BUTTON ON FRONT TO DO A SELF DIAGNOSIS.TV WAS PERFECTLY FINE BEFORE OUR LAMP BLEW.PLEASE HELP
  • 4 more comments
  • cliffie83 Dec 30, 2007
    Replaced the lamp, when hiting reset button blinks green and then the red lamp light button goes back on. no picture or sound.
    Help
  • sskellen Feb 17, 2008
    I have the exact same problem with a WD62827 television. Taking the lamp out and putting it back in seems to work sometimes, but mostly not. I have a hypothesis that there is an issue with the internal power supply in the television driving the television to turn the picture off to protect itself. Any ideas? Thanks.
  • harleydave67 Feb 27, 2008
    how do you reset the lamp? i just installed a new lamp and can't get any picture or sound at all.
  • Anonymous Mar 04, 2008
    I had a technician out and he conclusively determined the problem to be the electrical ballast that regulates current to the lamp. The part is on order, but the tech had a test harness with him and he was able to circumvent the bad ballast with his own and fixed the problem. I am handy and electrically savvy, but this looks like a job for a pro.
  • JB4375 Mar 08, 2008
    I have the 57 inch 1080p model that I purchased on 9/11/06. Since that time I've been through 4 lamps. Recent research has turned up a lot of people having the same issues, and I even seen one thread about a class action suit mounting.
    If I could get this issue fixed and have a bulb that "actually" last 4000 hours I'd be happy. I don't really feel about passing on my problem to someone else by fixing it, and selling it.
    I've so far I've heard it could be attributed to the ballast, faulty board, and the comment from Mr NiceGuy about the "3300mf 16v caps on the main power board that are the cause of these problems."
    MrNiceGuy: Could you elaborate on this? I realize it's a loaded question since it's not in front of you to look at. I'll take any info I can get at this point. Thanks in advance!!!
  • developerguy May 11, 2010
    how do you reset the lamp? My lamp looks like it is fine. I get sound but no picture. Timer light blinks and TV turns itself off.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 301 Answers
  • Posted on Mar 02, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
301
Questions
0
Helped
79258
Points
655
There are 2 3300mf 16v caps on the main power board that are the cause of these problems.
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Feb 12, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1710233
Points
8129
Take the lamp back out and reset the lamp
My model is WD 62525 have sound but no picture. For serveral weeks the tv would come on with blinking yellow light and then red lamp light would come on. We would unplug and wait a couple minutes and plug...
Hi , make sure you put the cover back on so it can press the switch to let the tv know door has been shut and will allow to light bulb.Also when putting a new bulb in the ballast, which is the board that powers the lamp, sometimes its not able to provide enough power to light it up because it was used to provide a lesser voltage on the old lamp.Make sure you reset the lamp timer I dont know the exact code for it but u can search it on your manual.Hve a blessed weekend!
Bulb is only 2 mo. old. i have sound but no picture. red light is on. tv shuts itself off
step 1. Try pressing reset button. step 2 if step 1 does not work. Remove front cover and lamp door press, defeat the safety switch with a screw to hold the lamp door switch in and check to see if the lamp turns on. If it turns on for up to 10 sec then turns off replace thermal fuse.
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Replaced lamp, no picture, turns to red light
please make sure to place Lamp Door/ Cover after installation of new Lamp in TV.
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
3answers
Mitsubishi Projection TV WD-62525
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
2helpful
5answers
Screen is black
Mine just went out today......1 year and 7 days after purchase.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
