Question about Onkyo TX-SR604 Receiver
Receiver keeps turning on and off also the standby mode blinks
Receiver keeps turning on and off also the standby mode keeps blinking
  • lpbrown408 Oct 15, 2009
    my receiver keeps shutting off and on.and the standby mode just keeps blinking
  • 4,234 Answers
The receiver is going into "protect" mode. This means that a problem has been detected and the unit shut down to prevent further damage. Without seeing the unit and taking some internal measurements, it is difficult to provide a complete solution. Typically, the output transistors fail which can cause this. There are other possibilities too. I would suggest that you get a detailed repair estimate from a local shop. With that information, we may be able to walk you through the actual repair.
Dan
Posted on Oct 15, 2009
6ya staff
SOURCE:
All of a sudden stopped working and won't turn back on. been 12hrs. when power is pressed, it turns on for 2 seconds and then standby lights blink again and it turns off
This could be caused by a direct short circuit on the speaker outputs. Try disconnecting all the speaker connections at the back of the receiver and then power back on. You can also try a factory reset by holding the surround mode + clear button for 3 seconds.
Feb 14, 2016 | Marantz SR7005 Receiver
Sr576 standby light blinking
Most likely, you have DC Offset(a bad amplifier). The unit is shutting down to protect your speaker system, as well as protect the unit from any further damage. If you require more assistance, or would like to inquire about repairing your Onkyo, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Jul 22, 2012 | Onkyo TX-SR576 7 Channels Receiver
Standby light blinking
if you have the blinking led problem on your SR4002 receiver, it is in protect / safe mode 1- turn on you receiver2- hold 'S speaker B' + 'ATT' + 'exit' buttons at the same time for 3 seconds3- it should turn back on normally
Feb 26, 2011 | Marantz SR4002
TV on Standby
There is a Sony S3000 protect blinks table:ebf219b.gif
May 27, 2010 | Sony KDL-32S3000 32 in. LCD Television
I just put the internet on my wii and now when i turn my wii off the light is yellow, not red, and the area where you put the disc in keeps blinking blue.
This is because you have wiiconnect24 turned on. wiiconnect24 keeps your wii in a standby mode so that you can receive messages when you are not playing the wii. When the disc tray is blinking blue this means you have a new message. If you want to turn wiiconnect24 off go into the wii settings menu then wiiconnect24. If you just want to turn the wii off fully then when you want to turn the wii off hold the power button on the wii down until it turns red.
Dec 30, 2009 | Nintendo Wii Console
ITS ON STANDBY MODE & NOT ABLE TO GET ITS DISPLAY
Try this, not sure if the same would work for ya.
Swich off the amplifier.
Prior to the process check the wires connecting the speakers are not creating a short circuit which is apparently putting the amplified into a standy mode.
1. Press the "A" "B" and power key all at the same time and hold on to it.
2. The amp will go into a reset mode and will keep blinking till it gives a normal "click" sound and the amp turns on.
3. this process would take about 2 - 3 minutes.
4. You may then release the buttons.
5. If it goes into a standby mode again and does not power on, or the standby keeps blinking, get assistance from the engineer.
6. Once it is on, you shall need to do the resetting of alll the configurations done earlier.
Hope it works, it costed me 3k to get the job done.
Nov 12, 2009 | Denon AVR-1603 Receiver
Blinking standby button
Hi...1st off ...make sure all the speakers are connected at both ends.
2nd..buy a new cat..one that doesnt drool.
If it's still stays in Stdby after checking speakers, It might have blown an internal fuse cause thats where those darn stereo people put them now.
Jan 09, 2009 | Onkyo TX-SR605 Receiver
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Onkyo TX-SR604 Receiver Logo
561 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
