I have problem on my nokia 6300.every time i connect with the charger its make a prompt of "warning.bad contact charger" so it cannot continue charging.what i will do?thanks a lot for your help.
Hi, this is what you do when your phone refuses to charge..
WHEN YOU'RE HANDSET REFUSE TO CHARGE.
1. Read the battery charging terminal if it is continually.
2. Read the board interface if it continually on the charging interface.
3. Read the charging put on continuity if it is continually.
4. If they are all contacting, still not charging, then you service it by W/H i.e. washing and heating.
5. If not still charging, you trace the charging interface with another board by means of looping.
REMEMBER:
The process by which you connect a tinny copper for an external construction, or a unit interface which is known as looping.
6. If it does not charge it them means that the charging IC is bad.
ALTERNATIVELY:
You may advice the person to buy a universal charger or desk top charger and extra battery for a better charge.
Best solution: Remove your battery, clean the contacts and reinstall. If the battery is bad, replace it. If the charger is bad, replace it. If these things don't solve your problem you are left with replacing the phone. Thank you !
