If someone could help it would be great. My Maytag Neptune front loader is leaking water fromt he bottom. We took the back panel off and can not see where it is coming from?!?!?! The problem started after my husband was fixing the toilet valve and had turn the main line on and off a few times (not sure if this had anything to do with it). Any ideas on what could be the problem that we could fix it ourselves. He is pretty handy....again we just can't see where it is coming from. Thank you!
Pull the frount panael at the bottom and look there early model neptunes would leak around the door seal they made a kit to fix them but i dont know how old yours is so i cant tell you if thats it check the obvious hoses etc your drain pipe could be cloged the one your drain hose goes down in and just barley running over when the washer drains tell your husband to fill it then then switch to drain and listen to the pipe will sound like a bottle filling up when it drains or he will see it running over while it fills look under the bottom panel for leaks hope that helps
