I have a Moen tub filler (Kingsley model) and the diverter won't move up and down. I wanted to take the spout off to see if I could get it fixed. I removed the stem from the top and took off the set screw. I thought that I could then just lift the spout of the stem, but it won't lift off. Is there a trick?
My Moen tub filler/shower plugger stopped working Removed set screw with allen wrench and filler would not come of. Turned counterclockwise with screw driver and it just turned and turned. Finally cut it off with dremel and hack saw to remove and replace. Wear a mask because it will make a mess. It was just straight pipe but fused on after 20 plus years.
