Do you hear it running? Usually there are two things that happen with wine coolers when they get warm. The first is a faulty cold temperature control, failing to turn the unit on despite our attempt. You should have one, possibly two or more fans. If you have any, and they do not run no matter where you set control, that is likely your problem. If you dont have any fans - you will likely have a black plate with some "bubbles" around the back and side walls, Then you may have to have a service company test your compressor, to see if the compressor itself or the starter has failed.
Assuming the other motors on the cabinet are running, you've narrowed
your problem down to 2 things, the compressor itself, or the start
device has failed. Without the proper tools you wont be able to test the
compressor first. My advice, go to repair clinic . com, see what a
starter will cost you, if you can find a repairman to check your
compressor for cheaper than what it costs to buy starter, well there you
go. Either way, if its the compressor thats bad, you wont want to spend
the money to replace, unless you have a built in worth several
thousand, or physical constraints of kitchen prevent you from buying new
fridge.
Visit:
www.FixMyFridge.net for
Chicagoland Refrigerator Repair Service or read our FAQ and Tips.
