I have sustained water damage in my bathroom. Water is escaping around the bath drain. I have temporarily stopped the leak by using a clear glass silicone sealant. Now, how do i pull the drain apart and replace a new seal???
Or use a pair of needle nose pliers and other pliers to turn. Also, do not forget to apply pipe dope (thread sealant) on threads after putty is put on.
Remove the hair strainer or pop up drain assembly if so equiped and using a basin wrench or two crossed screwdrivers unscrew the drain basket and remove from the tub. Clean the tub and the back side of the basket and apply a generous bead of plumbers putty to the backside of the basket and reinstall. Tighten it down squeezing out excess putty, wipe off excess putty and you are done.
Some people use silicone sealer in lieu of plumbers putty and it will work fine but is messier in my opinion and makes dis-assembly harder.
When you next get the smell, check the traps to see if there is enough water in there to fill the trap, if one is less then it looks like water is getting sucked out when toilet is flushed or that trap (usually bath or shower) hasn't had water going in (lack of use) and water has partially evaporated.
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
Need clarification....the drain leaks to the ceiling below, or it doesn't hold water? If it doesn't hold water, no need to replace the ring. Those can be adjusted. Simply pull up on on the lever and screw it in clockwise. This will lower the stop and hold the water. If it actually leaks below, unscrew said stopper, grab a pair of needle nose pliers and place them in the drain (to grab the strainer) and use another pair to loosen. Once off, clean around drain and clean strainer, apply plumbers putty to the strainer, apply pipe "dope" (thread sealant) to the threads and tighten back in. Good luck!
The seal for the drain is leaking. It is either the drain itself or the seal beneath the drain. If it is the seal beneath the drain then you will have water going underneath the whirlpool and causing damage; if it is the drain itself simply replace the drain as it's seal is either broken or worn.
the most common reason for a drain to leak is that the plumbers putty around the drain where it meets the sink or tub has dried out and has a crack or void in it. Unscrew the drain from inside of the tub and check the plumbers putty. There is an inexpensive drain wrench sold at hardware stores, lowes and home depot that makes this an easy fix.
hi
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
