If you want to know the correct tire size for your vehicle. Open the drivers door and look on the edge of the door under the latch. You should find a data plate that will tell you size of tire for your van and proper air pressure for front and back tires.
Testimonial: "very helpful "
Tire sizes are labeled on the sidewall regarding width,height,and wheel size.EXAMPLE:205/70/15
205 is tread width in mm
70 =side wall from edge to rim is 70 percent of width
15 =15 inch rim
speed & load ratings are 'letter'' designated.
Testimonial: "Great help thanks."
SOURCE: 87 Dodge Caravan Tires
If you go to (tirerack.com) it will guide you. Appears there were 2 sizes available. 195/70-14 was probably most common, and optional were 205/70-15
