Suggest you check the simple stuff first.
Not checking is akin to a car that won't start, and tearing apart the entire fuel system, only to find it was just out of gas.
1) Make sure the receptacle the surge protector is plugged into, has power. Surge protector Power On light should be lit.
2) Check THE receptacle in the surge protector, that the computer itself, is plugged into.
Have had a number of expense surge protectors, where just THAT receptacle was bad.
("Hmmm, surge protector Power On LED light is lit. Monitor, printer, sound system, and router plugged into the surge protector has power. Should be good to go.
NOT!
Plug a table lamp, or similar device into THAT receptacle.
Make SURE it has power)
Surge protector, and receptacle in surge protector checks out?
Bypass the Power On switch.
See if the problem is a $5 Power On switch, or the Power Supply.
(Generic ATX Power On switch that I have found fits many computers,
http://www.directron.com/atxswitch.html{The Power On switch, is located inside the plastic Power On button assembly}
This is information about computer Power Supply's,
http://en.wikipedia.org/wiki/Computer_power_supplyThis is a basic example of an SMPS, (Photo at upper right. You can click on the photo to enlarge), and info about.
(Switched-Mode Power Supply. The main type of power supply used in personal computers),
http://en.wikipedia.org/wiki/Switched-mode_power_supplyBy bypassing the Power On switch, you will be able to determine if the problem is the switch, or Power Supply.
Bypassing the Power On switch turns the Power Supply on?
Bad Power On switch.
Bypassing the Power On switch does Not turn the Power Supply on?
Bad Power Supply.
A jumper wire is used on the 20, or 24-pin ATX main power cable.
The jumper wire goes to the Soft Power On, (PS_ON. Green in color), to ANY Ground wire.
(ALL Black wires are Ground wires)
A MOMENTARY contact is used.
(Example of a 24-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24 )
In order to guide you in this procedure, I need to know the computer manufacturer name, and Model Number.
On a desktop computer this will be located on the Back of the computer tower, (Next to the Windows product key), or up on the side of the tower.
Some models have it where there is a door you open in the front, and the product number, or model number is located there.
Post back in a Comment.
