Sorry but there was no support driver listed on the CTX site available on your device.
Go HERE or try driver scan
HOpe this helps
Check compatability list at microsoft hardware. there maybe none ever written for this card
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
http://es.kioskea.net/s/Tengo%20audio%20driver%20download you will have to select an operating system
hope this helps
