Bose Wave Radio Logo
Posted on Oct 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Oct 14, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3735536
Points
36074
Products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
For manual copy and paste this link in your internet address bar under a new tab:
1 Related Answer
Anonymous
  • 16 Answers
  • Posted on Feb 22, 2009
SOURCE: Instructions; TIMEX Alarm Clock Radio w/CD Player & Nature Sounds
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS.
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
How do I set alarm? Instructions long gone
To the left of the display are two buttons, engraved "1" and "2". (Note, I'm NOT referring to the buttons for radio presets, which are below.)
Hold either of these buttons for a second or two to enter alarm set mode. The screen prompts will prompt you to set the time for the alarm to go off using the time set buttons to the right of the display. You can also press one of the radio preset buttons or the AUX or CD buttons to wake to one of those. Once you're done setting the alarm, quick presses of these alarm buttons turn the alarm on and off and choose between music and beeper.
As a side note, if you've installed the backup battery and the power fails during the night, the alarm will still go off with the beeper so you're not late for work -- a thoughtful touch from Cambridge Soundworks.
Instructions
From the manual:
Setting the Clock
1. Press and hold the Time Set Button until the display begins flashing
2. Press the Reverse or Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display
3. After setting the time, press the Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode
Setting the Calendar (It is important to set the correct date in order to use the 7-5-2 Alarm settings)
1. Press and hold the Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display
2. Press the Reverse or Forward Button to set the correct year, and then press the Enter Button. The unit will beep and the display will show the month and day. Again, press the Reverse or Forward
Button to set the current date
3. After setting the date, press the Enter Button or wait ten seconds to return to the normal display mode
Setting the AM/FM Radio Alarm
1. Press and hold the Radio Alarm Button until the settings and radio frequency appear on the display.
2. Press the Reverse or Forward Button to set the alarm time.
3. Use the AM/FM Band Button or the Memory Set 1-6 Buttons to select a radio station to wake up to. Adjust the alarm volume using the Volume Thumbwheel
4. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
5. After you have programmed the radio alarm, press the Enter Button or wait ten seconds to return to the clock display. The Radio Alarm Indicator will appear on the display, showing that the alarm is set.
Setting the Nature Sounds Alarm
1. Press and hold the Sounds Alarm Button until the settings and Nature Sounds Indicator appear
3. Use the Nature Sounds Button to select a nature sound to wake to. There is a choice of four sounds:
Sound #1: Ocean Surf
Sound #2: Forest Spring
Sound #3: Rushing Brook
Sound #4: Summer Wind
5. After you have programmed the nature sounds alarm, press the Enter Button or wait ten seconds to return to the clock display. The Nature Sounds Alarm Indicator will appear on the display.
Setting the Buzzer Alarm
1. Press and hold theBuzzer Alarm Buttonuntil the alarm setting appears on the display.
3. After setting the wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, Monday through Friday, or the weekend. Before setting the alarm, be sure that you have set the date, as shown in the Setting the Clock and Calendar section. While the display is still flashing, press the Date Set/7-5-2 Button until the desired setting is shown at the top of the display.
4. After you have programmed the buzzer alarm, press the Enter Button or wait ten seconds to return to the clock display. The Buzzer Alarm Indicator will appear on the display, showing that the alarm is set.
3helpful
LOST DIRECTIONS.. DONT KNOW HOW TO SET ALARM..or use this clock..CAN YOU HELP ME
You can download the manual for free using this link:
http://dl.owneriq.net/8/82dd8645-ef03-4b41-9b07-5a6b02655a1d.pdf
Setting and Using the Alarm
1. Press the AL SET button. The time will flash.
2. While the time is flashing press the HOUR button until you reach the correct hour. Then
press the MIN button until you reach the desired minute.
3. After 5 seconds the alarm set time will stop flashing and it will be programmed, or you may press
the AL SET button.
Note: The PM indicator also applies to the alarm. You can review the alarm setting anytime by
pressing the AL SET button.
4. To activate the alarm you may choose one of 3 wake options:
a. To wake to BUZZER press the AL MODE button once.
b. To wake to a SOUND press the AL MODE button a second time. It will set to the last
sound you listened to. If you wish to change it press the sound you wish to
wake to and then press the POWER button.
c. To wake to RADIO press the AL MODE button a third time. You may leave it on the
current station or adjust the TUNER.
Note: A green LED will appear next to the wake mode selected to indicate the alarm is set.
Thanks.
gylacz
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
2helpful
Set clock, date, alarm on SI686 CD/ Radio / Alarm Clock with Sound Soother
Can you clarify what you need help with? To SET THE CLOCK push the "Mode" button twice. (The current time setting flashes on the display) Once it is flashing, Decrease the hours by pressing "1" Increase hours by pressing "2" Decrease minutes by pressing "3" and increase minutes by pressing "4". If no additional buttons are pressed the time will reset in about 10 seconds and the display will stop blinking.
TO SET THE DATE press the "mode" button 4 times. The current date setting will flash on the display. Decrease the date by pressing 3. Increase the date by pressing 4.
Decrease months by pressing 1. Increase the months by pressing 2. The date will reset in about 10 seconds when you stop pushing the buttons.
TO SET THE ALARM Press the "mode "button once. The display will begin to flash. Change the hours by pressing either 1 (increase) or 2 (decrease). To change the minutes, press 3 or 4. 3 decreases the minutes and 4 increases the minutes. Once you have the time reset, leave the unit alone for about 10 seconds. the display will stop blinking indicating the time has been reset.
TO ACTIVATE THE ALARM push the round button on the far right. You will see the alarm icon come on or off on the LCD display on the right side. Be sure you have set the AM or PM time correctly on the alarm time. It helps to recheck this now as I have made this mistake several times.
If you get stuck on military time and want the 12 hour clock the answer is posted on this site, as well.
Hope this helps.
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
I cant find the manual so I dont remember how to set the weekday alarm. Also can you show a picture of what the display should look like when the alarm is set? Or describe it? Thank you.
Press the Alarm button. The weekday alarm symbol will appear. Then press and hold the Alarm button for 2 seconds to enter the set mode (the hour will blink). Use the up/down buttons to choose the hour for the alarm (note the A.M./P.M. if in 12 hour mode). Press Alarm again and the minute will blink. Again use the up/down arrows to set the desired time. Press Alarm once more to exit the set mode.
To activate or deactivate the alarm, press the Alarm button until the weekday alarm icon appears. Then use the up/down arrows to activate or deactivate the alarm. When the alarm is set and active, the time will show. If the alarm has been deactivated, then dashes will appear instead of the time.
The single alarm is set and checked similarly.
I hope this helps.
(I suspect that the weekday alarm icon continues to display when the alarm is active.)
4helpful
12helpful
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
