The plastic locks in the spot to put in the batteries in my S5000 have all broken. Any ideas what to do to keep the thing closed so that the batteries will work and I can take pictures. It's not the lid pieces but the clasps on the camera itself. Thanks.
SOURCE: Fuji FinePix S5000
This appears to be loose connector to the motherboatd from the screen.
Try gentle squeezing of the casing near the bottom of the body
This may do the trick- otheriwise it is a workshop job and frankly not worth the cost - the money would be better spent on a more uptodate camera.
SOURCE: battery cover
I had a look at my S5000 and see what you are talking about. Those tabs are part of the inner shell, likely expensive to replace if even cost effective. In the past, I have cut the broken tabs off, leaving a flush surface. I then drill small holes and insert large head screws that I file to match the door tabs. It does require some finite work but is possible without disassembly of the camera.
SOURCE: Fuji S3100 Broken Battery Latch
There are two potential solutions that I know of, but only if the broken tabs are on the door and not the camera body. Double check which tabs are damaged.
The first involves getting a new door somewhere (good luck with that... Fuji doesn't seem to sell the parts to civilian consumers... you might try getting the part from an old non-functional one on ebay or something). The trick to removing the battery door is to push the door's hinge pin (with the door open) towards the back (LCD side) of the camera from the opposite (front) side. There is very little clearance. I have successfully used a paint can opener to do this on a S3100. You can brace the back side of the opener against the lip of the camera body and push the pin out. Once it is as far out as possible, use needle nose plier or tweezers to grip the now exposed end of the pin and pull it all the way out. Then put the new door in place and re-insert the pin... there may be a little resistance.
The other was recommended to me by a camera repair man, but I have not tried. I would probably have let him do the work, as it seems a little risky, but possible. It basically involves getting a small washer that will fit under the two latching tabs near one another on the body. After figuring out the correct position for the washer to be attached to the door that it will just slide under the tabs and secure the door, you must use a small countersunk screw through the central hole in the washer to attach it to the door. You might have to remove the rim of the door in that area with an exacto knife or something similar so the washer will fit well. Like I said, I would have probably let him do the work, but it sounds like it would work.
Another idea that just occurred to me is a little more work intensive but would probably work would be to sink a (coarse thread) screw through the door all the way into the plastic of the body (maybe 2 or 3 in different places), which could simply be unscrewed any time you wanted to change the batteries with relatively little trouble.
Good luck! =)
SOURCE: Fujifilm Finepix S5000
the problem might be inside. when cameras are dropped cable connections inside loosen. try to bring it to your local camera specialist and have it checked. if you open it yourself it might cause more damage.
