Hi, if the drum is full of water or not fully empty, this will prevent the spin from working.
If you have a drain filter, see if it's blocked.
You may have a blocked drain pump, a block in the outlet pipe or the drain pump is failing.
All of the above should be simple to check and cheap to repair.
Hope this helps
