Have you tried holding the power button and the home key together. Hold until unit reboots and once apple logo appears, release both buttons. If this doesnt work try this below.
Try launching I Tunes on PC without I phone connected. Then make sure I Phone is switched off. Now hold down the home key (square at bottom of screen) Whilst still holding home key plug in your I Phone usb lead. I Tunes should identify you I Phone after few seconds and prompt " detected I Phone in recovery mode" (or similar) it should then prompt 'yes' or 'no' to do recovery. Select yes and let it start. This should resolve this issue as it did on my 3G version.
If still no luck search FAQ's section on www.apple.com
Hope that works/helps?
Press and hold Power and Home Button together for 10 secs and then release power button without releasing home button continue to hold home button (30 secs)
your phone will be in restore mode connect to iTunes after that and select your ipsw and then ....
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
