There are three screws that hold the top panel in place in the rear of the dryer. Remove these screws and the panel will slide back, then lift off. You should have access the outer perimeter of the drum, control board and control panel.
If you need to access the dryer bottom cabinet, remove the lower toe panel directly below the door. The panel comes off by removing the screws under the bottom front edge. With the screws removed, the panel will drop down and then come off.
NOTE: Propping the two front feet of the dryer up can offer better access to the toe panel screws ( a section of 2x4 works well for this).
There are some helpful exploded view diagrams you can use for reference at these following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Small items (like coins) can often get caught in the dryer drum baffles. They come off easily by removing the screws that hold them on place around the drum perimeter.
CAUTION: Make sure you UNPLUG the dryer before servicing anything inside the cabinet. Dangerous voltage is still present even with the dryer turned off.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
