Vtech i6772 Trio Cordless Phone Logo
Posted on Dec 27, 2007
VT ip8100 - enter base id problem
Both handsets display "enter base id" after an attempt to fix a broken vonage connection through the customer service help line. i enter the number on the sticker on the base but after the restart the phone asks for the number again, leaving me completely phoneless... is there another way to find out the base id on the phone since i think the sticker might just be plain wrong? one of the hansets is displaying "enter base id", I don't know where is located, the serial number at the bottom is DC850756607.  Does anybody know where  the base id is located?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
680
Points
24Ghz Vtech phones cant find base
  • Anonymous Dec 21, 2008
    entered the base # but they still cant find base
    Speaker phone light keeps flashing and phones cant find base, it looks like its stuck
1helpful
2answers
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3answers
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
I put new batteries in my At&T cordless phones and I am getting a message on phone screen T23 PD
To register a handset to your telephone base
Make sure the handset battery is installed and charged properly. You have to enter a 15-digit telephone base ID to register the handset to the telephone base.
To find the telephone base ID and register the handset:
1. On the telephone base, press the MENU softkey when in idle mode to enter the feature menu. Press the or softkey to scroll to the DISPLAY BASE-ID menu, then press the OK softkey. The telephone base ID will be displayed.
2. On the handset, use the keypad buttons to enter the telephone base ID and press the OK softkey.
Press the softkey to move the cursor.
3. The handset will first display PLEASE WAIT!!, then T23 PD followed by SEARCHING FOR BASE. The screen will finally display HANDSET X when the registration is successful.
NOTES:
1. If the registration is not successful, the display will show NO BASE SUBSCRIPTION. Try the registration process again.
2. If an incorrect base ID is entered, the base ID will disappear and ENTER BASE ID will be displayed.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 • Cell Phones
I need the base id for a vtech house phone model number 6772
It sounds like you are trying to register the handset(s) to the base. Once the handset is charged, if you see 'Searching for Base' on the display,(The bold is for your question specifically but I thought you may like all of the information for getting a phone hooked up) ON the Base unit press MENU, scroll down to Display Base ID, press OK, and the Base ID code will display. If NEW appears in your handset display, press the soft key under it and enter the base ID code you found in the base display. If 'New' does not appear on your handset, press MENU and then scroll down to REGISTER. Press OK and then enter the base ID code. If the handset is already registered, please deregister all then register again. To deregister a handset which is registered to the base model 20-2431, Using the soft keys on the base, press the 'MENU', then press the down arrow once until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 6 times, until 'DEREGISTER ALL' is highlighted. Press 'SET' . If your handset is registered to the base model 20-2481, Using the soft keys on the base, press the 'MENU', then press the down arrow twice until 'SETUP BASE' is highlighted. Press 'OK'. Press the down arrow 7 times, until 'DEREGISTER ALL' is highlighted. Press 'SET'.
Benjamin
Can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
1helpful
I just got this phone VTech 5881. I plugged it in and have tried to register the handset. I can't. It has someone else's name in it. what should I do?
First, deregister all handsets:
Step 1: At the base, press MENU, scroll to BASE SETTINGS, then press OK.
Step 2: Using the base dialpad, enter * * 3 3 5 7 8 2
Step 3: Re-register each system handset:
At the base, press MENU, scroll to DISPLAY BASE-ID, then press OK. The 15-digit base ID number will be displayed.
Step 4: Using the handset dialpad, enter the base ID number. Repeat the registration procedure for each system handset. Each handset is assigned a number in the order of registration
Registration problem
download the user manual from the motorola web site for your model
2helpful
3answers
EnGenius DuaFon 1X
Registration:
a. Press MENU-6 to enter the registration mode
b. Press and hold the base’s Registration (REG)
button for 2 seconds until 4 LEDs light up. (Located on the base where you plug in the phone jack)
c. Press handset key “1”, this completes the
registration process. When you register the
handset to BASE 10, the base will assign a
handset ID between 11 and 19. The assigned ID
will be displayed on the handset LCD, indicating
successful registration.
d. Repeat above steps for all additional handsets.
e. The first two handsets registered will be given ID
11 and 12, which gives them administrator
privileges.
2helpful
2answers
ya u need to contact v-tech vendor not vonage and gave them the serial no of ur handsets and get teh base id and try that will work
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
