My ps3 it goes green beeps twice then goes red and flashes on/off
Theres power going to my ps3 the red light comes on when i switch it on it goes green for a second then beeps then goes red and keeps flashing on and off.
Re: my ps3 it goes green beeps twice then goes red and...
You might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode... hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb) Thanks and take
its an error. hold down the power button till it beeps once. the hold it again till it beeps twice. The moment it beeps twice take your finger off and instantly hold it down again. your ps3 with give you 5 onscreen options, hit #3 and only number 3. that should fix the problem. You can also youtube "how to fix disk error on ps3" and people will should you how to do these stated steps.
insetad of restoring the filing system, restore the default settings ore restart the system
try safemode hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
Try reseting your PS3. Turn your PS3 completely off by the switch in the back. Then flip the switch back on. Press on the power button and hold it until the green light comes on, beeps twice then the green light should go out, replaced by a red light. Then turn it on normally.
