SOURCE: tv won;t power
These TV's are prone to power supply failure and this sounds like itmay be the case for you. I offer to repair/recondition the powersupplies in these TV's for a flat rate and I also have an instructableon how to remove the power supply located here( http://www.instructables.com/id/AKAI_LCT2715_Power_Supply_Removal/ ) Ifyou are interested in having your power supply repaired you can contactme in my profile( http://www.fixya.com/postBuddyProblem.aspx?budid=763646 )
SOURCE: my lg 37lc2d tv power light blinks 15 times and
The power supply is a common fault on this model.
Buy a replacement from www.chsinteractive.co.uk
Not cheap though.
Testimonial: "I found the part on partstore.com replaced it and works like new. Thank you"
SOURCE: TV was working until I moved it to another room.
It can be that the wire may have come loose inside. Are you getting any indicator light on the front panel at all? If you do, then the standby power supply is working but not the rest of the power supply.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
I have an LG as well.
My troublshooing says:
"Check the power control setting.The power supply may be interupted.
Check if the Auto sleep feature is actiated in the Time settings.
Refer to the " Sleep timer".
If there is no signal while the TV is on, the TV will turn off automatically after 15 miutes or so"
No power! How do I get the tv to work?
