I have bought a second-hand LFH 720. Does it record or do I need a separate hand held device like the LFH 388 pocket memo. Do they use mini or micro cassettes?
Thanks for your help
Hello I think what you want is to over record on a top of the previous dictation, but this recorder does not work that way example: let say that you are counting 12345678910 and you want to correct and add ACBD between 5 6 to listen back 12345ABCD678910. This recorder don't work that way, the only feature that this unit have is add or insert to the end, on the file that you are listen. During playback press REC for more than 1 second the record indicator appears and "ADD" will flash for 3 seconds in the display window the indicator will turn red and the new recording will be added at the end to the current message.
I really recommend if you want to used a Digital Recorder like the old style analog recorder with a slide switch this unit is really easy to operate and all the features that anyone needs, I think the price is not bad, is really a professional digital recorder http://www.tvps.com/Products/Philips-9380-Pocket-Memo-Digital-Recorder---New-LFH-9380__PH-LFH-9380.aspx
Hola que tal, desafortunadamente hasta donde yo sé Panasonic no ha actualizado Drivers para Windows 7 desafortunada mente así pasa a veces, en realidad té recomiendo que si vas a invertir en otro equipo consideres tus opciones ya que la verdad es mejor una grabadora de voz profesional y de una Marca líder en el ramo de las grabaciones como Olympus Philips o Dictaphone normalmente cada que sale un sistema operativo nuevo se actualizan muy pronto con el asunto de los drivers yo te recomiendo esta grabadora por su precio creo que vale la pena cada dólar http://www.tvps.com/Products/Philips-9380-Pocket-Memo-Digital-Recorder---New-LFH-9380__PH-LFH-9380.aspx
