Question about Olympus WS-300M Digital Voice Recorder
I erased files but even after 30 min it is saying memory full whats happened
  • 403 Answers
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser. Check out page 34, and 70 in your manual at this link.
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1193
Hope this helps, let me know if I can do anything else for you.
JimmyC
Posted on Oct 13, 2009
SOURCE:
Camera says card full
Your memory could be bad - try another chip and see what happens. If it does the same with that then the camera itself is at fault.
Oct 06, 2015 | Video Cameras
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
Is there a way to fix my recorder?
perhaps the manufacturer's tech support would know what and why if you contact them
Sep 10, 2015 | Audio Players & Recorders
It says "Memory Full" but
If you are sure you have erased all files in all folders then it would not do any harm to run FORMAT from the menu.
This may well clear your "Memory Full" message and get your device working again.
Hope this helps.
Sep 10, 2011 | Olympus WS-110 Digital Voice Recorder
My MR16 says HDD full- so I erased 12 songs and 10 wav files to free up space. No matter how much i erase it still says HDD full when i attempt to record. do i have to initialize and lose everything to...
I had the same problem. After some reasarch I found out that even if you erase a song the data is still on the recorder in "hidden files".
What you have to do is download the WAV manager software from Fostex.com, then copy all your files to your PC, reformat the hardrive on the Fostex, and copy the song files back on to the Fostex form your PC.
I know it's a pain in the ****, but I guess that's one reason this thing was so inexpensive.
I still am very happy with mine, but after 3 years of constant use in my case, some type of maintenence can be expected to happen.
Jan 01, 2011 | Fostex MR16HD/CD Digital Recorder
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
I have a 2 gig card that won't let you use that amount of room
Reformat he frame's internal memory.
1. Click on the "Macintosh HD" icon.
2. Click on "Applications".
3. Click on "Utilities".
4. Click on "Disk Utility".
5. "Kodak" drive should be in the list showing a white drive icon
6. Click that icon and select “Erase”.
7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below.
8. Try to copy the files to the re-formatted internal memory of the frame.
Dec 28, 2009 | Kodak EasyShare C315 Digital Camera
Im trinyg to change my wallpaper on my lg cookie, but it keeps sayin memory full, but i've got loads of free space.. help?
actually its the space in the phone memory not with the memory card,if it says memory full
remove your memory card and erase the data present in your phone memory and put the MC and change the wallpaper...
RATE ME!!!
tnx.
Jul 14, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
DON'T KNOW HOW TO ERASE MEMORY...
There may be files on ur Card. Check the card from PC adn if not tell me.
Jun 25, 2009 | Olympus Camedia D-435 Digital Camera
When i was in 30 min of play in the sims2 ,message popup saying internal grahics hardrive
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Initially, pls try:
  • update the video card drivers;
  • physically remove the graphics card and clean the little gold pins with a pencil eraser; or
  • if the video card is built in, then remove and perform the procedure on the memory.
Good luck and Thank you for using FixYa. Happy Holidays.
Pls be informed that due to my current rank and rating, even a Helpful would be detrimental to my status. Should this solution not address your concern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 24, 2008 | Compaq Evo N610C Notebook
Olympus WS-300M Digital Voice Recorder Logo
156 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
