Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi- I've just inserted a CD into my MacBook Pro
0 0 0 Hi-
I've inserted a CD into my MacBook Pro and for the first time it doesn't show the CD icon on the screen AND it won't eject.
When I press eject the "arrow" doesn't show, either. The CD doesn’t even show up on iTunes hmmmmm…
I've tried shutting down and restarting and pressing the escape/control/option keys....to no avail. There’s nothing on iTunes to help it eject, either.
Can you suggest anything?
Thanks,
Scott
Anonymous
Level 3:
President:
  • Master 2,600 Answers
  • Posted on Oct 13, 2009
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1017369
Points
8362
CD Stuck in Device
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
How to change region of CD drive Macbook Pro
To change the region of CD drive on a MacBook Pro, follow the steps below:
  1. Insert a DVD that is from the region you want to change your CD drive to.
  2. Open "DVD Player" application on your MacBook Pro.
  3. Click on "DVD" menu at the top of the screen and select "Region" from the drop-down list.
  4. A pop-up window will appear asking if you want to change the region, click on "Change" button.
  5. If prompted, enter your admin password to allow the change.
  6. Wait for the region to change, it may take a few minutes.
  7. Once the change is complete, you can eject the DVD and insert one from the new region you have set.
Note that you can only change the region of your CD drive a limited number of times, usually up to 5 times. After that, the region will be locked to the last region set, and you won't be able to change it again.
Software disc is too small, macbook pro will not accept the disc
Hi, if the Macbook can't read the Mini discs, you can copy the contents of the Mini Disc to any USB Flash Drive by inserting the Mini Disc in any Desktop Computer's CD/DVD Drive. After copying the Mini disc contents to USB Flash Drive you can install in the Macbook pro. var geo_Partner = '843689b9-ba30-459d-9c4b-876924715b22'; var geo_isCG = true;
Hi there, I got an Apple MacBook Pro, OS 10.6.7 and recently got problems connecting to my wireless internet at home. I've got no problems at all connecting to other wlans (at work, at friends'...
So you're knowledgeable, good. Do you have the SSID broadcasting or not? Do you have WEP or WPA, etc active? Can you find the network you are trying to connect to under preferences on your MacBook Pro? Does your network show up? Either way, delete it and start over. If you re-set up your network and it still doesn't find it, but the other machines in your house work wirelessly, it is still a configuration issue. Do you have your wireless network as the default network to find? Do you have a help desk that you can call at your workplace? Give me more details and i'll continue to try and assist.
Hi My laptop "MacBook Pro" first
First insert the CD you wish to boot to. Then let the mac start up all the way. Go to system preferences, then click startup disk. From there select the drive you wish to boot to. then select restart, and it will restart to that disk or CD.
My macbook pro desktop icons are gone! and the spinning wheel keeps going. Any ideas
Your hard drive might be failing.
If you have the original install discs that came with your computer, insert disc 1 into your computer. Then turn off your computer and then turn it back on again while holding down the Option (alt) key and double click on the CD icon that pops up. Then when the computer boots from the DVD, click on Utilities and the open up the Disk Utility application. Run "Repair Disk" with your internal hard-drive selected. If this program cannot fix your problem, you may need to invest in purchasing a new hard drive and replacing the one in your computer.
Hi, I m a new user of apple mac book, I m trying to insert a disk in my dvd rom but still i am not able to open my dvd player. Can u help me that how will be open the dvd rom in apple mac book? means any...
I would please like to tell you there is no button in MACBOOK to eject a tray as there is no tray.
You simply see a line on the right hand side of your laptop where you can insert a disc, u need to insert a disc into that part and when you insert it you will show you an icon on your desktop showing you the cd contents.
When you want to eject it keep in mind u need to click on the icon on your desktop and press the eject button or u can also use the keyboard and press the eject button, which will bring the disc out automatically.
Please do not worry try it, I'am sure it will work for you.
If there would be any problem and you need any help please do not hesitate to ask.
I'am also giving you a link to see the video of how to insert and eject the cd, please note this is the old model of the macbook, the only difference is that the drive is now located in the right hand side of the laptop, dont worry take a look.
http://www.youtube.com/watch?v=yWOQ-xlSKVE
Thank you.
Mac Book Pro won't burn cds - spits out the cd
try a real music cd to check drive.
some blanks are no good try another brand or try a dvd to check drive
if it plays real and records on dvd then drive is ok
I have a SanDisk Sansa m200 mp3 and a macbook pro
Even on a Macbook pro, you should be able to access your "my computer" option, where it shows you the local disk drives and everything. your mp3 player icon should appear there. then after you click on the icon it should bring up a page containing folders "on" your mp3 player. there doesnt have to be any music or videos or anything like that to have the folders already on there. now i dont have a mac but what i suggested you to do should work.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
