What is the meaning codes E00315-00B on the canon image runner 5000 copier?what should i do? Any bodies knows?i need the explanation.thanks you very much before.
e-000013, it is all about waste toner. possibility : - waste toner case was detecred full. - The PLL lock is
released because waste toner motor is locked up, etc. - The micro switch employed to detect clogging of waste toner is
activated. the position behind-below of copier. open the beck cover and you ll see it.
Hello Zak
The hard drive for the 5000 is located at the rear of the machine in the upper left controller box as you know. The 5870's hard drive is to the right, just below the "main board". Remove the back cover. To your upper right you will see the enclosure that houses the main board. Directly below it is a box with a cover on it. That's the controller box. Remove this cover and the hard drive will right at yours eyes. You have indicated that you are familliar with the 5000 series, which means you know how to proceed now that you have located the HDD. Have a great one !
hi;
you mean E00315-000d-00
this error code appears when there is a codec error the solution is :
1) replace the SDRAM
or
2) replace the HDD
or
3) replace the main controoler board
Please check the main thermistor TH1 has poor contact or open circuit.,the thermal switch is opened.In this case the fixing heater has opened and the SSR is faulty. For the reset : COPIER-FUNCTION-CLEAR-ERR.
