Question about HP Officejet Pro L7680 All-In-One Printer
DEFAULT IS MIRROR IMAGE - HOW DO I TURN THIS OFF
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 54 Answers
  1. From the Windows taskbar, click Start and then click Run .
  2. Type control printers in the Open box and then press Enter . The Printers and Faxes window displays.
  3. Right-click the HP product from the list of printers and then select Properties . The Properties dialog box displays.
  4. From the General tab, click Printing Preferences . The Printing Preferences dialog box displays.
  5. Click the Advanced tab.
  6. Under Printer Features , click Mirror Image , click the down arrow (DEFAULT IS MIRROR IMAGE - HOW DO I TURN THIS OFF - c01320592.gif ) to the right of the field, and then click Off .
  7. Click OK to apply the change.
Posted on Oct 13, 2009
6ya staff
SOURCE:
Suddenly print in mirror image
I'm almost positive that the printer setup is causing this problem. To fix this you will need to go to
Printer Properties... then
Finishing....
Under the header: ORIENTATION ..... UNCLICK the "MIRRIOR IMAGE"
Then make that format your default or it will continue to switch back to Mirror Image....
I hope this helps, if it does please click the thumbs up!
Jun 28, 2011 | HP Officejet Pro L7680 All-In-One Printer
I am having a problem finding out how to do a mirror image and where to send my scans to myself on my Pixma MX330
I print reverse images (in Word) for t-shirt transfers by going into the printer properties. Select the "Main" tab and for Media Type select "T-shirt Transfers." I believe that it prints the mirror image by default.
Nov 17, 2010 | Canon Office Equipment & Supplies
HOW DO I DO MIRROR IMAGE PRINTING
go to start, printers and devices, double click on your default printer (the one with the check mark) click on adjust print options, click ok on the popup window, click on the advance tab and there you will see different options for your printing preferences. click on the plus next to printer features, you will see mirror image and it will say off next to it. Click on it and change it to on. click apply, ok and you'll be set! To turn it back off just use the same process but select off under mirror image printing.
hope that helps!
Oct 10, 2010 | ASUS Computers & Internet
How do I stop printin in mirror image? I already
go to the printer from the control panel on your pc and verify the defaults are set correctly. if you are changing it in word for example it may only do it for the one time you are trying to print. usually if you right click the printer and go to properties, you'll see the settings there.
Jul 12, 2009 | HP PSC 1610 All-In-One InkJet Printer
Changing a Printing Shortcut turns mirror setting ON and OFF.
The paper was tightened(delayed). I have not switched off the printer and with effort have extended a paper. Despite of it on the screen it is constantly offered to clear the printer
Jul 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printer is printing job as a mirror image
go into the properties setting for the printer, go to advanced tab, then to the prinint defaults button on that tab. When you click on that - if you go to the advanced tab within there, you will see "mirror image" and i bet it says "ON" - click on the word mirror and it opens up the ability to set this back to off. Hope that helps!
Mar 26, 2009 | HP Officejet Pro K5400n - - colour -...
HP L7580 printer prints mirror image
Turn the mirror image option to on. If it does the same turn it off than uninstlall and reinstall the complete software.
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Hp officejet pro l7680
To solve this problem, you need to set the mirror image to 'off' under the advanced tab of the printing defaults and under the advanced tab of the printing preferences buttons. We had this problem for some time and since doing the above this has stopped.
Steve
Oct 23, 2008 | HP Officejet Pro L7680 All-In-One Printer
Printing backwards
When you get the print window, click "Properties", then click on the "Advanced" tab. Look for a "Mirror Image" menu item. It should say "Off". If not, click on it and you should get a drop down box to change it to off.
Oct 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
  • Go to the Printers Menu and select Add Printer
  • Add a Local Printer
  • Create a new port - type: local port
  • For the port name, enter the share of your printer on the remote computer.  For example, if your computer name is superDesktop and the printer share name is megaPrinter, you'd type in \\superDesktop\megaPrinter.
  • Finish the wizard and you're done, printing normally!
Oct 14, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
399 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
