Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
Anonymous Posted on Oct 13, 2009
Funai VCR/DVD recorder DVR 2737. My -R discs record ok but during finalising I get disc error - cannot record on this disc Error code E22. Can you help?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
855
Points
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
4answers
I transferred some pictures from my computer on a Maxell RW disc. When I played the disc on my Funai DVD/VHS Dual recorder model DRV-2737 no picture appeared on TV screen. What could be the problem? On the...
sorry...it seem like your dvd/vhs player is outdated...(do the rw disc plays in pc?) are you using Nero software? this will curve the problem...or try another DVD RW brand that funai is compatible with...dvd players, dvd recorder and pc dvd burners do roll back...all must be a year or less apart to work with each other....
5helpful
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 • Motorcycles
2helpful
2answers
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
1helpful
DVDs from DVR don't play on any other DVD player
yes when you have finished the recording and preferably when the disc is full the disc must be finalised to be compatible with other players but be aware if you finalise a disc you cannot record on it anymore
3helpful
Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
17helpful
9answers
Funai DRV-B2737 Error message
I'd had this problem with my 2737 for quite some time but haven't had the time to fix this until now.
Just for the record it has one laser unit inside which fires off two frequencies one for read the other for write. Anyway, I've been repairing Playstation 1 and 2 and Xbox for years and the most common problem seem to be disc read errors caused by seemingly failing lasers or scratched/damaged discs.
The manufacturer sets these lasers at safe usable limits but after some use they start malfunctioning.
I wanted to copy a VHS recorded disc to my PC tonight only to find I hadn't finalised it in my Funai.
Realising I couldn't because of the silly E4 54037380 error I finally took the plunge and dismantled the unit.
NOTE: the following is not for the faint hearted and please use an antistatic wrist strap to earth yourself.
The Disc tray mechanism has to be removed and a small circuit board directly to the right has too be released. There are a plethora of ribbon cables but only one needs disconnection. Carefully turn the disc drive mechanism on it's back and un clip the thick ribbon cable that attaches to the laser. Tuck the cable out of the way being careful not to damage it. Move the lens unit to the top of the tray mechanism and note there are two potetiometers Using a pot tool or fine flat bladed screwdriver adjust the lower pot by an eigth of a turn (this increases the frequency of the recording laser enough to eliminate the E4 54037380 error completely or it did in my case).Problem solved fully working recorder.
Dismantling procedure
Disconnect Funai from mains and remove the top casing (5 screws)
There are 4 screws holding disc drive mechanism in front right most tricky (use grabber tool to retrieve screw)
Top right has an earth cable connected to it
The other end of the earth cable is held in by another screw on the circuit board next to the drive mechanism this also needs removing
The screw directly below this with the metal earth case strip remove.
The board is held on by two small plastic lugs which need compressing so the board can pop up.
Remove drive mechanism carefully along with the circuit board and flip the whole lot over. Be mindful of the ribbon cables as they are fragile
1helpful
Funai drvr-b778 dvd record problems
try mr dvd-r discs from poundland they seem to work
My dvd recorder no longer records
take your DVD player to a tech and your problem will be all over.good luck
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
