Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
We have a photocopy canon MF 6530 and on the screen appeared information Platen glass dirty , clean platen glass.
I have clean glass there we put paper for copy , but it seems that is not this problem, Photocopy stoped copy or print it use just paper.
Could you please let me know what do I need to clean.
(This is for your information)First ur problem is not mentioned clearly. You are mentioning network printing is having problem (this is ok) but it is not clear that printing from USB is having problem or not. And you did not mention the type and version of your operating system(OS) and the nature of your network. Installing driver is very crucially depend upon the OS and the type of network that you are having.
Let assume that you are having genuine MS Windows 2003 Server as the backbone of your network and genuine MS Windows XP SP2 as the OS of the client PCs. Some basic knowledge of networking is required to understand and execute the remedy mention below. And you should read completely first before trying out this.
For network printing problem of Canon ir3035, first check the physical network cable(UTP) if it is properly crimped & properly connected, then check the connectivity by pinging the IP of the copier (which is needed to set manually if there is no DHCP server in the network). If the copier is responding properly. Check again by pinging the server from the copier (which you will find under MENU and NETWORK OPTIONS of the copier). If both the way is responding properly uninstall the printer driver totally and restart the system. Re-install the USB driver first and then re-installed the network driver (before re-installing the network driver first check whether it has got the required IP from the DHCP server, if not assigned one according to your network). If there is no error message during the installation of the USB driver(normally USB installation does not show any error), USB printing should be ok. Thus USB case is close.
Then check the network by using the same procedure mention above. If everything is ok, you can carry out the installation process for network driver. This way there should be no network printing problem. If still there is the problem please check that you are not using pirated copy of OS. Network printing for ir3035 is not ok if pirated copy of OS is used. You have to get a genuine copy and will solved the problem A to Z.
Hello tophams,
I wish I had a magic wand to help you...but the answer is YES! You can fully control the priorities of how the 7105 handles printing/copying/scannng requests. I truly understand your dilemma, it is merely a matter of how the device has been configured. You can program the device to give priority to copies, which will cause print jobs to wait in the que until your copies are done. You can have the print jobs sent to a "mailbox" so that the person requesting a print job will have to walk up to the device and "summon" their print job. There are so many ways to help you with this. You will have to get "THE BOOK" out. I can't type all of the options available to you.
