Dear,
You can test you smps simply by shorting any of the back wire and green wire. this will switch on your smps withour connecting with mother board. IF it the fan rotate, SMPS is ok.
If you need more trouble shooting on SMPS you have to measure the volate on each wire after powering on.
More info
http://www.smpspowersupply.com/connectors-pinouts.html
what kind of computer is it? Did you re-check everything and all the connections are ok? Did you check to make sure the on/off switch on the back of the computer is "on"? When you look at the back of the computer - is the little light inside coming on? Can you check the power supply in another computer to make sure it is ok?
