Land Rover Master
- Posted on Oct 13, 2009
Re: Is it difficult to replace the combination light...
It all depends on the tools you have and if you have patience....this is the task for removing and replacing the switch:
Removal & Installataion
CAUTION
These models covered are equipped with a Supplemental Restraint System (SRS), which uses an air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column and instrument panel, disable the SRS and refer to the precautions in the Chassis Electrical Section.
Make sure the steering wheel is in the center position (wheels in the straight ahead position)
Remove the key from the ignition.
Disconnect the negative battery cable first, then the positive cable.
Wait 10-20 minutes for the back-up power to discharge. Do NOT proceed until the back-up power is discharged from the SRS system!
Remove the driver’s side air bag module and steering wheel, as outlined under the Steering Wheel Removal & Installation procedure in this section.
Remove the steering column nacelle, as follows:
Open the fascia lower access panel.
Remove 3 screws securing steering column nacelle halves together.
Release clips securing nacelle together and remove from steering column.
Exploded view of the steering column nacelle (cover) mounting
Remove the rotary coupler, as follows:
Release rotary coupler connector from bracket and disconnect from harness.
Disconnect rotary coupler connector from harness.
Remove rotary coupler.
is it difficult to replace the combination light - 36a7806.gif src="/uploads/images/36a7806.gif" alt="36a7806.gif" class="h_mi" />
View of the rotary coupler
Release passive coil from steering column lock and lower the coil without disconnecting the harness.
Release front wiper delay connector from column switch mounting bracket and disconnect from harness.
Disconnect harness connector from wiper switch.
Remove 2 screws securing switch, carefully raise edge of switch bracket is it difficult to replace the combination light - c23a31c.gifcation peg and remove switch.
Release front wiper delay connector (3) from column switch mounting bracket and disconnect from harness. Disconnect the wiper switch connector (4), then remove the switch mounting screws (5)
To install:
Install the new switch to bracket and secure with screws.
Connect harness connector to switch.
Connect front wiper delay connector and Install the connector to switch bracket.
Install the passive coil to column lock.
Install the rotary coupler, as follows:
Install the rotary coupler to steering column and connect connector to harness.
Connect rotary coupler connector to harness and secure to bracket.
Install the steering column nacelle, as follows:
Position the nacelle to steering column and secure with clips and screws.
Close fascia lower access panel.
Install the steering wheel and driver’s air bag module, as outlined in this section.
Connect the positive, then the negative battery cables.
