I replaced the black cartridge and the the printer prints an alignment page each time i start up the printer. I cant find the alignment set up program --which i have done a hundred times before .
I just got off the HP help line. After changing my black ink cartridge a test page was printing each time I turned the machine on. This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink. I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty. It turns out that you cant do it. HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings. And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer. The printer was inexpensive sure, but I'm paying for it in wasted ink.
Unfortunately, you have to replace both the black AND the color ink cartridge. In the meantime, you can stop the test page from printing - after it starts - by pressing the cancel button on the printer.
Here's a link to the HP page that describes this problem. For me, it turns out my color ink cartridge was low on ink. I replaced it and the alignment page that used to print each time I turned the C3100 on no longer prints out. Hooray!!! :)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336397&lc=en&cc=ca&dlc=en&product=428800
AFTER CHANGING BLACK CARTRIDGE MY PRINTER PRINTED TEST PAGE EVERY TIME I TURNED ON THE COMPUTER FINALY I CALLED HP TECK HETELLS ME IF THERE IS NO COLOR ON THE TEST PAGE TO REPLACE COLOR CARTRIDGE LOW AND BEHOLED THIS CORRECTED THE PROBLEM SO IF YOUR COLOR CARTRIDEG IS LOW YOU WILL HAVE THIS PROBLEM MATT
Yes, the problem of the alignment page printed every time the printer started up was solved by just REPLACING THE COLOR CARTRIDGE, which was low on ink indeed. Thank you.
Scning is ok but didnt prinet
Http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp? Go to this site and check for it.
Turn on the printer. WHen it asks for page then dont close the program. put a page and press the copy black button on ur printer. An allignment page will be printed and this problem will be stopped.
How to install printer HP Photosmart C3100 to my Toshiba-Vista?
thank you.valentyna
I have exactly the same problem.
I tried the scan the alignment page method but to no avail--still printing the alignement page on start-up. I unisalled the printer and re-enstalled it --SAME problem.
Same Thing!
I have the same problem, I can not figure out what to do to stop this. I re-installed the cartridges, didn't work. I ran the alignment software, still prints the alignment page ever time I start the printer.
REPLACED BLACK CARTREGE AND IT PRINTS A TEST SHEET EVERY TIME I TURN ON PRINTER DID NOT DO THIS BEFORE I ALWAYS BYE HP PRINTERS I AM DISAPOINTED THIS TIME AND I DO NOT GET ANY INPUT ASPECILY AFTER FINDING OUT THAT OTHER PEOPLE ARE HAVING SAME PROBLEM I HAVE TAKEN SAME STEPS AS EVERY DID THANK YOU MATTHEW SCIORTINO
keeps printing an alignment page after changing black cartridge
aaa
Tengo el mismo problema. Cada vez que enciendo la HP C3180 empieza a hacer el test. YO LO PARO APRETANDO VARIAS VECES EL BOTON DE ERROR, HASTA QUE SE PARA. :)
I have the same problem. Â I turn on my printer and each time it is running a test sheet! Â This takes time and uses my ink. Â I have have HP printers before but I am disappointed in the lack of support on this one! Â It is not user friendly. Â I cannot find anywhere to adjust settings related to this problem!
Well aye have the same ink cartridge and i replaced it because
How to reset the ink status? When I changed to a new cartridge the ink status still low...How to clear this up? Thanks!
I have the same problem and am very annoyed because it's wasting all my ink.
ive cleaned and aligned but black is real light in big font and bold selected or not at all in normal mode
