Re: Manuel for humminbird 565 dual beam fishfinder with...
If you go to Humminbirds Website and click on the Support Tab on your units page, it will give you the option to download the user manual to your computer.
I have no idea, I use these same ones and havve several mounted and they are used both in summer and winter, never had one leak. I also looked up these and did not see where there were any issues with this problem. I suggest you call Humminbird and talk to them, they are usually very helpful.
Toll-free: 1-800-633-1468 Monday - Friday 8:00am - 4:30pm CST
yes, generally there is an inline fuse on the hot (red) wire. it is incased in a white sleeve that twists apart and reveals the fuse. if its not the fuse check the battery or connections to the back of the depth finder.
Hi! Installation of the speed/temp wheel is quite easy, here's a manual: SW Speed & Temp The new sensor cable plugs into the square plugin in back of your Humminbird....it's the small square connector with 4 holes. Best of luck! Mike
Hi! If the sounder works in deeper water then try changing the unit to fresh water instead of salt water (or vise-versa). You'll need to switch to advanced settings first (in the setup menu tab), then switch to the afformentioned salt or fresh water (in the sonar menu tab). Alternatively, switch back to factory defaults as these settings are made to work "right out of the box". Best of luck! Mike
