Pride Celebrity 3 wheel. The free wheel lever slowly moves to free wheel while moving. Have to push it back down all the time. how can i stop it from working up into free wheel?
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
BEFORE U RING TRY THIS TAKE KEY OUT PUT FREE WHEEL LEVER IN FREE WHEEL THEN PUT IT IN DRIVE PUT KEY IN & TRY OT. Hi again get in touch with pride www.pridemobility.com or ring them 1-800-800-8586. They might B ABLE to help cheers if the electronics r the same as celebrity put freewheel lever in drive & remove key then :::: put it back & try it out good luck
Check for error codes. Move free wheel lever in and out a few times in case the brake micro switch is not making correctly.
Check speed control is not turned down low.
The freewheel lever is in the neutral position (which allows you to move the scooter around by pushing it. Turn the key switch off then move the lever to the drive position , turn it back on and it should run fine. The freewheel lever is sticking up through the plastic cowl. It is located under the seat on the right hand side near the rear of the sccooter
Hi, it could be that the throttle has turned around within the throttle lever therefore no longer centre, look under the throttle stem, you should see a cross head now that should be in align with you when sitting on the scooter...you will need to loosen the throttle and realign if that is the case...
Hi John.
The problem could be a worn throttle pot ( wig wag ). Next time you are driving the scooter, try moving the ends of the speed lever slowly up and down, instead of in or out as you normally use it. If the throttle pot is worn, moving the lever this way will make the machine speed up or slow down.
Another cause might be a faulty battery lead connector or a faulty motor connector.
Good luck. Neil.
