Question about Polaroid TLA-01911C TV
Polaroid TLA-01911C TV - I seem to have the same
Polaroid TLA-01911C TV - I seem to have the same probels that most have. I turn on the Tv and it works for about 10 sec then the screen goes blank. I have researched the problem a bit. I changed the capacitors, and it worked for about 30 sec. until I heard a high freq. buzzing then it went dead again. what should be my next attack? and how would I test it? mjb
    Problem Solver:
  • 19 Answers
I had the same problem - replaced the capacitors which cleaned up the signal. Then I hear a "buzzing" from the CCFL lamps. Turns out the solder job on the CCFL's themselves was shoddy and corroded. No good CCFL Power trips the inverter and turns the lamps off. Resoldering the wire to the end of the CCFL's fixed the problem permanently.
Posted on Dec 08, 2009
    Problem Solver:
  • 15 Answers
This model has the inverter and the power supply on the same board
changing it might help, if the lamps inside your lcd monitor are good, i have couple of those waiting for power suply/inverter board.
good luck
Posted on Nov 30, 2009
  • 541 Answers
You probably have a bad inverter PCB. It is a skinny board by itself over on the left side of the back of the panel.
Posted on Oct 13, 2009
SOURCE:
Fix sound on Polaroid TLA-01911C TV
Audio amp may be blown. A cable may be bad.
What are you connected to?
Apr 04, 2014 | Polaroid TLA-01911C TV
POLAROID TLA-01911C turns on but only white screen. no sound
Hello
The main board has the fault. Your set need a thorough check before confirmiing the fiault.
This is the picture of the board. OK.
Feb 16, 2012 | Polaroid TLA-01911C TV
Not really a problem but. I need to remove the base from a Polaroid TV model # tla - 01911c to get it into a box to ship
Good day!!!
all you need to do is to get Philip screw driver and remove all screw that connected to the base of your TV after that you can freely remove that base...
Thanks for using fixya...
Aug 11, 2011 | Polaroid TLA-01911C TV
Need a manual for Polaroid TLA-01911C
http://www.hdtvreview.com/Polaroid-TLA-01911C-hdtv.html
May 07, 2011 | Polaroid TLA-01911C TV
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
My tv tla-01911c drowned on the flood. is there any solution to fix my tv
even if you dry it opening everything, the water might made the permanent damage already
my opinion is
NO you can NOT repair
Oct 01, 2009 | Polaroid TLA-01911C TV
I have a Polaroid TLA-01911C. I switched from cable to air and did a scan, but no channels are found. I even hooked up an antenna with no channels found. Any suggestions?
Ether the antenna is not good enough for the digital signals that are now brodacasted or you got a bad digtal tuner in this unit. i would buy a antenna from radioshack special for this TV.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 18, 2009 | Polaroid TLA-01911C TV
Will Not Find A Signal Polaroid HD 15" TV - Model TLA-01511C
same (tla-01911c) issue when trying to watch over the air brodcast try rescanning the channels that normally works for me
i got direct tv basic set on my S-video input so i only need over the air when the sat is down (i.e: storms, wind, snow, ...)
May 15, 2008 | Polaroid TLA-01911C TV
Polaroid TLA-01911C TV Logo
618 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
