I received a Sandisk Sansa View 8GB for Christmas and tried to connect it to my Dell Inspiron laptop (XP SP2). It would not connect to the laptop. I connected with the USB cable and the PC indicated a new MTP device was attached and then indicated that a problem has occurred during installation and your device may not work properly. The Sansa View device was not recognized and did not appear in My Computer.
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
What I have to do to connect my sansa view to my pc is...
step 1 - power up both.
step 2 - connect data cable to sansa.
step 3 - slide the lock button to lock the sansa.
step 4 - while holding the left direction on the thumbwheel count to 10 or 11.
step 5 - plug USB cable into computer.
may need to download software first but most newer computers automatically downloads drive when unit is connected. other than that you should be good to go.
There seems to be a problem when connecting the sansa view to a dell computer when the player is set to MTP. I suggest that you use the MSC mode when using the sansa view.
My SansaView mysteriously stopped playing .wma files...
I wonder why!?
Windows media player
Changing MTP to MSC fixed it. Thanks a million.
Make sure to remove the MicroSD card and format separately.
Format and restore to factory settings (without MicroSD card)
The Sansa View will be seen by XP and Vista. If you have a music service, do not place any music on the MicroSD card.
Place music service files on the Sansa internal memory. As the days comes close to renew, any music service mp3's placed on the external MicroSD ard, will not renew. A software bug Sansdisk must fix.
Ernest Jones
[email protected]
Change the mode from MTP to MSC
the computer will not recognize it. its charging the MP3 player, but it wont show up in the computer
please help
it wont conect
no able to see device on my computer
I have a windows vista. when i plug in the player it says the device was installed. but in my media player, the mp3 player is not recognized.
wont recognize device
i have the same problem!it doesn't appear on my computer
My HP Pavillion with Vista does not recognize my Sansa View 8g. Is there a fix?
How do you change from MTP to MSC if you can't connect? My properties are not available on the device alone, it needs to come up on windows explorer
but if it's not recognized I can't access it
my screen was broken and now it wont play music, plus when i try to connect it to my laptop, it isnt recognized and i cant do anything with it
I connected my new sansa view to my dell inspiron notebook and it said it was connected but my computer wont recognise that anything was connected, when I disconnected it totally the lcd still says it is connected?!
when i plug in my sansa view 8 gig mp3 player to my computer that only music files that can be seen are the ons that came with sansa view 8 gig mp3 player meanwhile I have at least 400 mp3s on it it has been updated what can I do
i recently got my new sansa media player 4 my b_day witch has 8gigs and well wen i pluged it in it woulnt let me it ssaid media player not pluged in.what should i do.
same as above
Same prolem as initially described.
When i try to connect my sansa view to the computer with USB, i hear a weird sound. Normally when you connect a device by USB, you should hear the same sound with any device. My sansa view has worked perfectly for 4 months or so, and now the connection by USB makes a different sound...and it is nog recognized. Anyone familiar with this problem?
Firk's "Sandisk Sansa View 8GB = would not connect"
i'm having the same problem. i tried in auto detect and in msc. when i put it in my comp. it says mtp device detected and then it says its completed downloading. then i cant find it. I have a dell inspiron 1520, running vista, and wmp 11. PLEASE HELP ME @[email protected] thank you
change the mode from MTP to MSC
I am not a genius at technology so im sorry for asking this type of question but how do you change the mode MTP to MSC and what is that
