I have a singer golden touch and sew 750. The needle hits the bobbin case. It doesn't go into the hole of the case. There seems to be a timing problem. How can I reset the timing?
Sounds like your needle is hitting the needle plate instead of going through the tiny hole down to the bobbin. Try using the handwheel slowly and watch. Or perhaps the needle is hitting the bobbin case. Something has been knocked off the straight I think. Has your machine been dropped or dmamaged?
have you tried turning the bobbin the opposite way in the bobbin case? it's also possible that the sewing machine may need some type of adjustment, it would be a good idea to have it check at a sewing machine repair shop.
try changing the needle--make sure it's the right needle for the fabric being sewed rethread the machine top and bobbin make sure the bobbin is inserted into the bobbin case it's also possible that the machine could have a timing problem and needs to be checked
On the right of the black bobbin case there are two screws, you can slacken those screws off and move the bobbin case nearer to the guard leaving enough room for the thread to pass through, if the needle is hitting the bottom you may need to retime the machine.
