If you don't have documents, pictures,
etc on the hard drive that you need to backup, try running system
recovery by doing the following (not sure if this works on the version
with a solid state drive):
1. Turn on the computer
2. Press and hold Alt + F10
3. Click on Restore System to Factory Default
4. Ensure the netbook is plugged into AC power instead of running off the battery and click OK
* This will return your netbook to the condition it was in from the manufacturer.
THANKS! *high five* I spent a bunch of bucks on usb flash drives tryin to get this to work and this simple trick did the job. YOU ARE THE MAN!
You are awesome!!! Thanks :)
works great thanks man..
It works thanks man...all the other site told me to put an OS system disk in which the acer one does\'t have a disk place.
Sounds like the harddisk has crashed, get a program called partition commander or norton commander and run either on them to to reset the hard drive. You'll need a new operarting system like winxp,or vista to use laptop again.
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes:
