this is a problem with the thermistors and will need a technician to come out and fix it for you, the part #'s are aw100052 and aw100053 for the thermistors but you have to enter service mode to clear and reset the code.
if this answers your query please rate my answer accordingly
The switch that detects the open cover is probably broken or stuck. Do this. Lean / press on the cover while trying to copy. Does it work then? If it does, you know for sure that the switch is stuck. If it doesn't, the switch is broken.
How to find this switch? Is there a small plastic tab on the cover that goes into a hole that you can see? Those are usually where the switches for such covers are located. Spray some electronic parts cleaner down this hole (available at auto parts stores). See if this helps any.
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
The fuser assembly can be removed by sliding it out from the front of the machine. You may have to remove a retaining screw and plastic knob, all are accessed by opening the front copier cover. Unplug machine from wall before attempting this.
